Car thump
Old Aug 16, 2014 | 02:33 PM
blue_strip's Avatar
Car thump
So, for the past two days while I've been driving 75+ I've heard a large thump almost as if I've hit something, it sounds like it's coming from the below my shifter
Not sure of this is just me hitting something, I have lowered it an 1" in the front and 1.35" in the back, not much, any help would be appreciated!
Old Aug 16, 2014 | 10:04 PM
Chris Gregg's Avatar
Get Off My Lawn
More info. Is thw road flat, level, and smooth road? Or are you experiencing it hitting bumps?
Have you looked underneath? Your exhaust look to be hanging low? Could be then that one or both of the exhaust isolators are busted. One is near the engine located right before the flex section. The second is located right behind the resonator, before the first bend around the gas tank.
Old Aug 17, 2014 | 11:35 PM
blue_strip's Avatar
Flat az freeway, i was recently messing with the exhaust and all of the isolaters checked out fine, I am starting to experience a shaking when I first get up to a speed but after I've passed it it goes away at that speed and below, is this just bad springs, bad cv joint(did notice a lot of splattering on one side the other day, may have been water) or over acceleration, I do accelerate aggressively
Also I don't think I've hit anything recently, not certain though
Old Aug 17, 2014 | 11:36 PM
blue_strip's Avatar
To clarify on the bumps and exhaust, I have not been scraping or bottoming out, also my exhaust has been left stock and the isolaters were not modified in anyway
Old Aug 19, 2014 | 02:29 PM
Get Off My Lawn
Your drop is really not that low for these cars, about what I'm at and I clear most everything just fine (except really steep drive way exits - but I also have a 6" round resonator on my 3" catback).
I'm just trying to figure out if something is happening that is causing the thump (ie: transmission shift, dips in road, etc).
If the road is smooth, exhaust is good, then I'm at a loss. However, trying to think outside the box, the only thing other than the exhaust that is located below the shifter is the ebrake cable. Do you use it? Sometimes the lines can freeze up (rust) and maybe that is the cable freeing itself? Maybe the cable has come loose under the car and is smacking around on the heat shield? You should be able to work around the stock exhaust to remove the 10mm bolts holding it in to inspect the lines.
That's all I've got. Let us know what you find.
Old Aug 19, 2014 | 03:42 PM
blue_strip's Avatar
I forgot to give an update, it looks like the exhaust is sitting about 1" above the suport brake car just after the catalytic converter and I'm thinking that may be what is causing the thump
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
