Rust Problem
Old Aug 20, 2014 | 11:05 AM
Tomocarlos's Avatar
Rust Problem
First time posting and this may be a previous discussion but I wasn't able to find anything related. The crosspiece below the radiator on my 2K Max is rusted out in the center where a motor mount(?) attaches. Is this replaceable or can I have someone do some creative welding or is it a lost cause? Thanks for any feedback.
Old Aug 20, 2014 | 11:09 AM
The_Fixer's Avatar
its called lower rad support and it is covered here with many different fixes
Old Aug 20, 2014 | 11:15 AM
Carguy1709's Avatar
Same thing happened to my 2002 Maxima. I took it in to my buddies body shop and had him cut out the half that was still remaining lool. Then had him custom weld a new picece in and now its stornger than it every was. Good luck!
Old Aug 20, 2014 | 12:08 PM
NmexMAX's Avatar
dot dot dot ...
Common problem.
https://maxima.org/forums/5th-genera...diator+support
Old Aug 20, 2014 | 04:00 PM
ac max 92's Avatar
As previously stated there is obviously a few fixes and threads. You could also check your local scrapyard and possibly find a solid one reasonably priced. Goodluck!
Old Aug 21, 2014 | 08:49 AM
djfrestyl's Avatar
Suspension Yoda
I would NOT buy a used crossmember, regardless of condition.
Also, the aftermarket ones don't last very long.
I'd get an OEM piece and install the entire thing, or cut and weld in stronger metal appropriately.
Old Sep 1, 2014 | 01:06 PM
Tomocarlos's Avatar
lower radiator support
OK,thanks for all the info. So I've ordered the OEM part from Courtesy and I've removed all other front end parts and I'm getting ready to use my new handy dandy HF spot weld drill bit and my neighbor is bringing home a MIG welder this weekend.
Mar 12, 2020 12:06 AM
ajahearn
Sep 19, 2015 03:03 PM
MaximaNoob1
Sep 18, 2015 01:01 PM
sdotcarter
Sep 2, 2015 09:53 PM
