Gutting precats
Old 08-28-2014, 07:26 PM
Tyler Kadlec's Avatar
Gutting precats
I've looked in this section looking for answers but cant find anything! My 5.5 is throwing 2 o2 sensor codes. I can tell my cats are clogged and I want to gut them. From what ive seen everyone talks about a sim or non fouler. Do I really need those? What are they? I don't have emissions or anything out here so im not worried about that. I just want my car to run normal and get my mpgs back! any help would be appreciated.
Tyler Kadlec is offline
Old 08-29-2014, 01:10 AM
colt149's Avatar
Secondary 02 sensor monitor the condition of the precat. If the car have error code for secondary 02 sensor, you need to replace the precat , gut it or install headers.The cheapest way is to gut it and install nonfouler to the secondary 02 sensor so it will not trigger SES light. If you live outside tristate, you can install headers with 02 simulator.
colt149 is offline
Old 08-29-2014, 02:05 AM
Fakie J Farkerton's Avatar
false.
Fakie J Farkerton is offline
Old 08-29-2014, 08:07 AM
D.Stillwell's Avatar
^^ Yes, of course. Bad o2 sensor? Replace the ****ty cat! Great advice.
D.Stillwell is offline
Old 08-29-2014, 09:06 AM
colt149's Avatar
The primary 02 sensor or upstream 02 sensor is located before the catalytic converter to determined the level of emission and unburned gasoline.
The secondary 02 sensor or downstream 02 sensor is located after the catalytic converter to measures the emission after the converter If the emisson data between the primary and secondary 02 sensor is the same. The vehicle's. ECU will trigger an error code, which turns on the Check Engine light.
Iam referring to error code specific only for SECONDARY 02 SENSOR
colt149 is offline
Old 08-29-2014, 09:12 AM
Anyway, to answer OP post = Yes you will need at least one sim or anti-fouler. Some people need both banks, some (like myself) get away with just one. That depends on the car too, IE. vq30 vs vq35
Old 08-29-2014, 10:14 AM
TallTom's Avatar
Like this man said, you will need sims or nonfoulers. It's cheaper/easier to just get the nonfoulers. You will need two (one for each secondary o2). It will keep the SES light from coming on and throwing a code
TallTom is offline
Old 08-29-2014, 11:03 AM
If I don't get Sims and it throws the code, will it decrease any power of my car? I tried to gut them last night but had a stripped bolt on my y pipe. Its the vq35 by the way. Thanks for the input so far guys!
Old 08-29-2014, 01:03 PM
colt149's Avatar
The SES light will stay on. As long as the precat is gutted, it will not affect the engine performance. If you have a lot of corrosion , you need a torch or WD40 or you will ended up breaking those corroded nuts and bolts.
colt149 is offline
Old 08-29-2014, 01:56 PM
TallTom's Avatar
You don't have any performance issues. You will just have an SES light glaring at you day and night until you do something about it.
TallTom is offline
Old 08-29-2014, 09:49 PM
cdoublejj's Avatar
why would you need to replace the headers? i could understand if they were cracked.
cdoublejj is offline
MaxRPM6
09-11-2015 06:56 PM
paulpearl
09-02-2015 07:50 AM
george__
08-18-2015 07:06 PM
1992maximase30
08-05-2015 09:27 PM
Quick Reply: Gutting precats
