Problems installing Courtesy FSTB
Old Nov 13, 2000 | 06:14 AM
jzwu's Avatar
Hi, all,
I was trying to install the bar on my 2001 GXE. But the driver side strut tower has a piece of metal soldered on it that is in the way of the plate. I cannot put the plate in.
Also, the piece of metal supports some wiring with a small black cylinder thing clamped on it. The cylinder is too protruding in the way of the bar too.
Any one else has the same problems on the 2001 Maxima? Please let me know what I can do. BTW, the bar is from Courtesy Nissan but it seems to be a generic bar from previous model years, i.e., it is not customized to specifically fit the 2001 Maxima.
Thanks, Yuan Wu
Old Nov 13, 2000 | 06:26 AM
Maximizd's Avatar
Originally posted by jzwu
Hi, all,
Thanks, Yuan Wu
You gotta cut that piece off with a hacksaw, or ghetto rig it by hitting it with a hammer (I DIDN'T do that, but I heard that someone did!). There is a site with pics on how to hack it off, and if done correctly you will not even know that the piece was there to begin with.
Here is the link:
http://web2.airmail.net/scutchen/max_faq/stb/index.htm
Good Luck
Old Nov 13, 2000 | 06:41 AM
Jeff K's Avatar
Courtesy's bar is generic..>
and that is the problem when installing it in a 2000 plus car. This thread talks about the Stillen bar and that it came with a spacer that will lower the small black cylinder so the bar will not hit it. You might have to bend the bracket the holds the small cylinder and as for the other part that covers the strut mount, that will need to be cut.
<A HREF=http://forums.maxima.org/showthread.phtml?threadid=8170>Stillen bar</A>
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
