Fog lights
Old Sep 10, 2014 | 04:36 PM
argenis69's Avatar
Fog lights
Hello,
Is there a way to wire the fog lights to stay on when the high beams are on, but not bypassing the fog lights oem switch?
Thank you.
Old Sep 10, 2014 | 04:53 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
yes do a search and you will find the How to....
Old Sep 10, 2014 | 05:30 PM
argenis69's Avatar
I typed that in the search engine before posting this thread and there's nothing specific
Old Sep 10, 2014 | 05:35 PM
Ghost_54's Avatar
Originally Posted by argenis69
Hello,
Thank you.
http://www.shiftice.com/how_to.html
Old Sep 10, 2014 | 06:21 PM
argenis69's Avatar
Originally Posted by Ghost_54
I check that website, been there before and already did that procedure, but fog lights turn off when I put the high beams and that's what I'm looking to fix.
Old Sep 10, 2014 | 08:30 PM
DennisMik's Avatar
That is the way Nissan wired the headlight switch to work. The fog light switch goes through the headlight switch and when the headlight switch is in either of the 2 high beam positions, it cuts off the fog light switch.
So what you will have to do is go into the steering column and find a white connector made for 6 wires (that may or may not have all 6 wires in it). Verify that the wires go to the fog light switch. One of the wires is a solid green wire (no stripe).
On the side that goes to the fog light switch, cut the green wire. Strip the insulation off of the end and connect it to a ground.
Code:
   connector E152
║ 33 ║lock tab ║ 31 ║
║ 63 ║ 61 ║ 32 ║ 62 ║
pin 32 solid green
pin 31 green/orange stripe
Old Sep 10, 2014 | 08:38 PM
a33_ridah's Avatar
who do this mod??? cool factor??? mountain runs? additional light up close of car and up high?
Old Sep 11, 2014 | 05:22 AM
argenis69's Avatar
Code:
   connector E152
pin 32 solid green
Thanks for all the information
Old Sep 11, 2014 | 07:15 AM
TallTom's Avatar
Code:
   connector E152
pin 32 solid green
Yeah, the government set a standard that they didn't want anymore than four lights on at any given time.
Old Sep 11, 2014 | 10:33 AM
DennisMik's Avatar
I did not know that - but given how the government loves to stick their fingers into every aspect of our lives, I'm not surprised.
Old Sep 11, 2014 | 10:45 AM
argenis69's Avatar
Exactly, what I was going to say, especially the PD, they suk biiiiiiig time.
Old Sep 12, 2014 | 09:24 PM
Itz Shak's Avatar
I don't see the point, but goodluck with that.
Old Sep 13, 2014 | 12:42 AM
Not sure if this will work in your 02, but it may be worth a look.
http://www.vqpower.com/v3/content/fo...n-maxima-00-01
Old Sep 13, 2014 | 10:14 AM
DennisMik's Avatar
The fogs will still turn off when the high beams are turned on because of the design of the head light switch.
The mod by shiftice and the vqpower mod are the same thing - power the fog lights from the tail lights instead of the head lights. The headlight switch design causes the fog light relay to de-energize in the high beam position, so a second mod is needed.
Old Sep 13, 2014 | 10:52 AM
Binfamous's Avatar
I rewired my fogs last week but instead of running the fog wire to the tail light I ran it through the AC relay so I can have the option of running the fogs with or w/o the heads. Also, when the car is off so are the fogs.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
