alt issues
Old Oct 4, 2014 | 10:15 AM
heavychevy's Avatar
alt issues
Hello everyone I'm having a hell of a time with car stalling out do to low battery voltage. Cleaned the grounds checkedthe aapt and main fuse swapped another apt in there has good belt tension I'm stumped cars an 03 6 speed
Old Oct 4, 2014 | 10:32 AM
DennisMik's Avatar
Check the small 2 wire connector on the alternator and make sure it stays plugged in and that the contact pins are not backing out of the connector.
What is the voltage output?
Also, what is the apt?
Old Oct 4, 2014 | 10:53 AM
heavychevy's Avatar
Voltage is around 13 when running then it drops down quickly as the battery loses charge. I made sure the two pin plug is for.my seated but didn't check thepins iI will do that now. What is apt?
Old Oct 4, 2014 | 10:54 AM
heavychevy's Avatar
Apt was alternator fuse my bad
Old Oct 4, 2014 | 12:26 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
the volt should read between 13-14.5 when tested at the battery. If the Alt test right the battery could be going bad, the Alt is charging the battery is not holding the charge
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
