What tools do I need for my Tokico install?
I'm planning on installing Tokicos this weekend. I would like to get everything ready for the install. I know I need a spring compressor and some wrenches. What size wrenches do I need and if there's anything else that I may need please advise me. Thanks.
Re: What tools do I need for my Tokico install?
i did it by hand the first time and took me about 6 hours
kafene
Make sure it is a STRUT spring Compressor, not just a standard spring compressor. Cause the standard spring compressors compress from the inside of the spring, which is not possible on the max since the strut occupies the space inside the spring.
The wrench you will need to take off the bottom bolts I beleve were a 19mm and you need a breaker bar. I am almost 99% sure it was a 19mm, 1% of me thinks it was a 17mm. Other than that the standard wrenches to take off the top three bolts under the hood.
Um the back struts, you will need a universal-swivel head for your socket wrench because it is in a awkward spot and your socket ratchet will not reach it straight up.
Other than that, 3hrs of time, and possibly a friend.
Dixit
Dixit
3 hours?
Dixit [/B]
Dixit [/B]
kafene.
Re: 3 hours?
Originally posted by kafene
dang, i think i spent about three hours just hand wrenching the spring compressors. are you talking about 3 hours w/ hand labor or w/ air tools?
kafene.
kafene.
Dixit
for the big bolts, I used 15-19 mm sockets and i think i used a 22mm. I used some more common sockets 8-12 mm to remove the bolts off of the mounts.
MaxLife17
06-27-2019 02:37 PM
