power steering issues
Old Oct 27, 2014 | 08:59 PM
palmer06's Avatar
Okay, Ive been having trouble with the power steering in my maxi pad. I live in NE and when cold weather rolls around my steering gets tight and doesnt want to turn untill the car is warmed up but even then its still not smooth. i put a remanufactured rack and pinion in it and it helped a ton but still having the issue with it. i also checked the U joint on the steering column and they are fine. think a new power steering pump will help or think the rack that i got is forked up ? any input would be great. thanks
Old Oct 28, 2014 | 09:39 AM
00Lightsout's Avatar
before the R&P did you just fluid flush with the right fluid?? Most people would do the pump before the R&P
Old Oct 28, 2014 | 09:59 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
flush the system and use Mobil 1 AT fluid.....
Old Oct 31, 2014 | 08:29 PM
I believe the R&P is not 100% usually the pump won't give you sticky spots, it'll give you consistent resistance. there are videos on YouTube to diag a steering system, yours sound seems symptomatic of the R&P failures.
lowpost99
Oct 26, 2025 06:53 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
sdotcarter
Sep 2, 2015 09:53 PM
coasterswim
Sep 2, 2015 07:43 AM
