Erratic tachometer needle 02 SE
Old Nov 3, 2014 | 05:32 AM
02nismaxlegnd94's Avatar
For the past 2 weeks now I've noticed that my needle on my Tach is bouncing all over the place, but the engine rpm are stable. it just the needle bouncing all over the place. last night it was dancing to my music, when i turned the radio off it went back to normal while stopped at a light.
as i started driving again with music now off, the needle was all over the place again. I've searched but came up with nothing pointing me in the direction for my 02 Maxima. any one else have any similar problem/ solution?
BTW its a 6 speed manual
Old Nov 4, 2014 | 12:29 AM
wow almost 24 hours later and after 54 or so readers, not one person experienced this on their 5.5! ill keep searching, maybe ill get lucky.
Old Nov 4, 2014 | 05:00 AM
Fakie J Farkerton's Avatar
No codes?
Scan anyways even if there isn't.
I assume it's either your cluster or speed sensor.
Old Nov 4, 2014 | 11:37 AM
The_Fixer's Avatar
Your Alty is starting to go bad
Old Nov 6, 2014 | 12:58 PM
FanaticMadMax's Avatar
your tach is bouncy around, it possible the cluster gone bad or you definitely got an electrical issue
Old Nov 13, 2014 | 12:29 AM
it's not a constant occurrence it's just once in awhile if i drive it hard, but since the speed limit here in NYC went down to 25mph, i just cuuise and the jumping isn't showing up right now, someone mentioned my alternator going bad?
Old Nov 13, 2014 | 12:30 AM
man i miss my Legend Coupe
James92SE
142
Jan 2, 2024 09:23 AM
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
jchronis2552
Sep 21, 2015 05:52 AM
magneto112
Sep 10, 2015 12:52 AM
