Washer size for door sag fix?
Old Nov 6, 2014 | 11:38 AM
Colossus's Avatar
I tried installing two different sizes of washers on my lower door hinge but the washers bent both times. The washers are large enough to fit over the threads, but it seems when I start to tighten the nut, apparently the washers cant slip over the base of the screw/bolt.
Anyone else realize they need larger washers? Or am I doing something wrong?
Old Nov 6, 2014 | 12:38 PM
FanaticMadMax's Avatar
the door sags?! I never seen that happens, my Maxima is over almost 14 yrs old and never had an issue, still close and a nice solid thunk just like the day I bought her brand new. Must been a lot of slamming the door or bent the hell out of it.
Old Nov 6, 2014 | 01:23 PM
ManualMaxima's Avatar
5th Gen till she dies!
My drivers door sagged (or became sagged due to unknown circumstances), years ago I did the same thing as the OP after reading a thread about it. I don't remember the size of the washers I used, because I probably just grabbed some outta the toolbox. OP just get some slightly bigger washers, it doesn't have to be precise. I will say it has worked like a charm for about 5 years now.
Old Nov 6, 2014 | 01:53 PM
ateick's Avatar
Not sure what causes it but I've noticed this year mine is starting to rub against the latch. Maybe the previous owner let it fly open in a wind storm or two. I know it's a big problem with Altima's as well.
Old Nov 6, 2014 | 02:33 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
i have the same issue but too lazy to work on it, lmao.. but i will work on it this weekend,
Old Nov 6, 2014 | 03:17 PM
2damax's Avatar
My door doesn't sag but it is super stiff. Needs lots of muscle to open and close it. It is the passenger side door of my crappier maxima so I do not care to fix it. Never a door sag issue though.
Old Nov 6, 2014 | 04:32 PM
Cotozic's Avatar
I had a sagging driver side door for a few years, and I recently decided to take it to a local body shop for a paint repair.
I mentioned to the shop that my door was sagging, and they fixed it right then and there for free with a metal bar. It took two of them, but they just bent it back up.
Perhaps this wasn't the 'ideal' repair, but it has held up ever since, and they did an amazing repair... so I'll credit them.
So perhaps brute force is an option?
This thread has a guide:
https://maxima.org/forums/5th-genera...0-minutes.html
I was gonna try that until the shop pried mine back.
Old Nov 6, 2014 | 05:23 PM
nismomaxgtr18's Avatar
Both of my front doors developed a sag after 16 years. I ended up replacing the front door hinges and now its like brand new again.
Old Nov 6, 2014 | 07:35 PM
Colossus's Avatar
It's very common with Maximas. My '02 I35 is in excellent condition with 58k miles with a slight door sag. How many miles does your Max have?
Old Nov 7, 2014 | 06:37 AM
ONE BAD Maxima's Avatar
What he said. Just make sure you do both the upper and lower. If you only do one, the sag will come back.
Old Nov 7, 2014 | 10:12 AM
JonBlz's Avatar
a.k.a. STuNtMAN
added washers to mines and its been good so far....my washers bent a little bit due to me tighten it alot but they been great so far
Old Nov 7, 2014 | 12:00 PM
It has 81k miles on the car, just can't help but wonder what cause to sag. I seen a lot of fords and GM car sags since their doors are heavier than Nissan and they use door Pin and bushing to remedy the sagging door, but Nissan doesn't have pins just Hinges.
Old Nov 9, 2014 | 07:16 PM
Biatchzxz's Avatar
I have been trying to fix mt sag for a while. I gave up. But I want or fix it. I just can't seem or understand how to install a washer on Hinge. How can. I get the hinges on when irs like bolted closed or whatever. I'm confused on how yu guys are doing this. Where ans what are taking apart an s I believe the washer was 1/8" from what I read
Old Nov 26, 2014 | 11:31 AM
JonBlz's Avatar
a.k.a. STuNtMAN
here you go bro : this is what i followed and it worked flawlessly
Old Nov 26, 2014 | 12:17 PM
Biatchzxz's Avatar
Thanks man. Yah I ran across this thread recently and saw that they cut a slit in the washers to slide them in. Which makes sense. Cause I couldn't figure out how they got the washers in without doing something like that.
Old Nov 27, 2014 | 02:29 AM
JonBlz's Avatar
a.k.a. STuNtMAN
what i did is loosen both bottom bolts and moved the door a little bit and put the entire washer in there but you can do it like in the thread seems much much easier
minsbang
Sep 11, 2015 08:48 PM
ag90fox
Sep 9, 2015 12:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
