oil leak from filter area
Old Nov 15, 2014 | 07:21 PM
mrsandman's Avatar
Can anyone take a guess as to where all the oil is coming from? I have read on here that the o-ring in the oil cooler is a likely culprit, but that area looks fairly dry. Anyone have an idea? I may just end up replacing the cooler o-ring and hoping for the best.
Old Nov 16, 2014 | 08:57 AM
Emaximus's Avatar
I can't open the picture for some reason, but have you changed your oil recently? If so, I would check to make sure the old gasket it completely off.
Old Nov 16, 2014 | 03:48 PM
mrsandman's Avatar
Haven't changed it in about 5 months...I put very limited mileage on the car.
Old Nov 16, 2014 | 05:04 PM
Donkeypunch's Avatar
Spray the area with brake cleaner and drive around, check the area every day.
Old Nov 16, 2014 | 05:48 PM
MONTE 01&97 SE's Avatar
That appears to be either the Oil Pressure sending unit or that infamous oil cooler o' ring, when that happened most of us the oil did not appear to be coming from that area either and looked like in your pic.
Old Nov 16, 2014 | 06:05 PM
Just hope it's not the oil pan gasket I'm going through that right now
it's sorta a pain because the y-pipe needs to come out so that means new gaskets :/
Old Nov 17, 2014 | 05:01 AM
Mattx's Avatar
Make sure there isn't two gaskets on the filter.
Old Nov 17, 2014 | 08:03 AM
Prophecy99's Avatar
oil cooler o ring, very common and cheap part and easy to fix. i would try that
Old Nov 17, 2014 | 04:43 PM
mrsandman's Avatar
I think I'll change the o ring and hope for the best.
Old Nov 18, 2014 | 07:00 AM
Prophecy99's Avatar
keep us posted, it is prolly the culprit.
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
97_GXE
20
Sep 17, 2015 08:12 PM
seesole
Sep 14, 2015 12:38 PM
ag90fox
Sep 9, 2015 12:22 PM
