Engine Mount Help
Old Nov 22, 2014 | 04:32 PM
eclivic's Avatar
Engine Mount Help
So I need to replace my engine mounts in my car Its a 2000 GXE 3.0. I am not sure if I can replace them with Solid non Electric mounts without getting a Code. I see online some say have sensor, some say Have solenoid, some say solid...I dont know what to get...I would like to eliminate the electric ones if possible. But if not, Which ones are Solenoid,Sensor and solid.
Old Nov 22, 2014 | 04:42 PM
george__'s Avatar
You can replace the auto with regular but there maybe some more vibration in the car
Old Nov 22, 2014 | 04:50 PM
eclivic's Avatar
Thats Fine, I just cant set off any codes because we have E-Check in MD
Old Nov 22, 2014 | 04:55 PM
george__'s Avatar
It won't
Why don't you just want to replace with a OEM or OEM spec part though?
Old Nov 22, 2014 | 05:07 PM
eclivic's Avatar
It won't
I dont want electric mounts just in-case I ever have issues with the IAC, I dont want to loose an ECU
Old Nov 22, 2014 | 05:09 PM
george__'s Avatar
have you checked the circuit diagrams in the fsm to see if this can happen?
Old Nov 22, 2014 | 05:12 PM
eclivic's Avatar
Im VERY new to Nissan's, I'm a Mitsubishi, Chevy Owner so I am still trying to learn everything i need for this car. I don't know what to look at or where.
Old Nov 22, 2014 | 05:23 PM
george__'s Avatar
This should help
http://www.nicoclub.com/FSM/Maxima/2001/
Old Nov 24, 2014 | 11:15 AM
djfrestyl's Avatar
Suspension Yoda
It can happen, it has happened to many, and it is the reason you SHOULD replace with non-electric mounts.
Old Nov 24, 2014 | 11:42 PM
eclivic's Avatar
I haven't ordered the mounts yet because I need to know 100% if I get non Electric mounts if it will set off a check engine light. If I have a cel in my state I cant pass Emissions check.
Old Nov 24, 2014 | 11:48 PM
Fakie J Farkerton's Avatar
No CEL from unplugging the mounts.
Old Nov 25, 2014 | 12:32 AM
eclivic's Avatar
So I found this set online. I know the part numbers are different because I think its a Manual Tranny set even though it says auto on the site.
Would Manual mounts work on a Auto since im not doing electric mounts??
1995 - 2001 Nissan Maxima 3.0L Motor & Trans. Mount Set - for Automatic Transmission
* This Mount Set has 3 Motor Mounts & 1 Trans. Mount.
- A7305 : Front Motor Mount - without sensor
- A7304 : Front Right Motor Mount
- A7302 : Rear Motor Mount - without sensor
- A7303 : Transmission Mount
Old Nov 25, 2014 | 12:49 AM
eclivic's Avatar
Or I found these on RockAuto
WESTAR # EM9251 Front Right; Automatic trans
$15.20 $15.20
DEA # A7305 Front; Standard trans.
$23.79 $23.79
DEA # A7302 Rear; Standard trans.
$27.79 $27.79
Transmission-Automatic : Transmission Mount
DEA # A7313
$51.79 $51.79
Subtotal $118.57
Old Nov 25, 2014 | 06:03 AM
nestorlugo's Avatar
NO sel.....Don't worry ,I'll be more concerned about the ecu getting fried, i swaped mine for the cheap Ebay kind,(doing poly fill when they fail)who cares is the car feels like a big azz battery powered toothbrush during idle jkjkjk vibration people descibe is not that bad
Only thing was the set of four i bought 3 fit perfect but the tranny mount was made from thin metal while the oem AT mount was made from beefy alloy so washers were needed to make it fit right...buy the alloy one if you want a perfect fit on that one
Old Nov 25, 2014 | 06:27 AM
george__'s Avatar
I agree. Top complains I get
- Your car is broken (due to the vibration caused by the mounts)
- Your car is too stiff
- Your car is too loud
Old Nov 25, 2014 | 07:45 AM
The only manual mounts that won't work on auto is the transmission mount.
Old Nov 25, 2014 | 08:52 AM
eclivic's Avatar
Does anyone know what Tranny Mount I should get for a 00 Max Auto
Ive seen an A7313 and A7303
Old Nov 25, 2014 | 09:09 AM
nestorlugo's Avatar
Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item...846058&alt=web right here buddy...
Old Nov 26, 2014 | 12:18 AM
maxiiiboy's Avatar
RockAuto.com has quite a selection, as noted in one of the above posts. 1AAuto sells a complete set of four mounts for 2000 AT Maxima for $108, shipping included; check it out:
http://www.1aauto.com/infiniti-i30-n...=681380&y=2000
Old Nov 26, 2014 | 12:47 AM
Originally Posted by maxiiiboy
1AAuto sells a complete set of four mounts for 2000 AT Maxima for $108, shipping included; check it out: http://www.1aauto.com/infiniti-i30-n...=681380&y=2000
Those mounts are complete crap and should only be used for poly filling.
Old Nov 26, 2014 | 05:14 AM
D.Stillwell's Avatar
^^ Energy suspension polyurethane FTW.
http://www.energysuspensionparts.com...sp?prod=7.1114
Old Nov 26, 2014 | 06:01 AM
eclivic's Avatar
https://www.rockauto.com/catalog/mor...210&cc=1359222
This is what mount I have in my car now on the passenger side.
Old Nov 26, 2014 | 06:42 AM
eclivic's Avatar
Part Number Part Type Price EA Core EA Quantity Total
2000 NISSAN MAXIMA 3.0L V6
DEA A7305 Motor Mount $ 23.79 $ 0.00 1 $ 23.79
DEA A7302 Motor Mount $ 27.79 $ 0.00 1 $ 27.79
WESTAR EM9251 Motor Mount $ 15.20 $ 0.00 1 $ 15.20
Shipping Priority Mail $ 12.74
Order Total $ 79.52
This is what I ordred, I'm going to wait on the Tranny mount until I take a look at it to find out if mine is the Aluminium one or steel one.
Old Jan 4, 2015 | 06:27 PM
double zero's Avatar
Thanks for the information! I just bought a 2000 Maxima and have been having trouble with shifting and noise.
Old Jan 4, 2015 | 07:14 PM
jr schultz's Avatar
The cheapest way that works well is to buy used manual mounts or inexpensive new manual mounts and fill with poly.
I used this product on mine:
http://www.energysuspensionparts.com...sp?prod=DIYMMI
wyobbagy
Jan 3, 2023 12:03 PM
derekinthez
Nov 13, 2022 04:00 PM
seesole
Sep 14, 2015 12:38 PM
ballerchris510
Sep 11, 2015 05:29 PM
spidgeon
Sep 9, 2015 03:36 PM
