BBK... options
Old Nov 30, 2014 | 10:09 PM
Roman777NYC's Avatar
BBK... options
so iv been looking into upgrading front brakes after winter... and got some questions... with the 370z akebono calipers do i just need a bracket and brake shield? the lines are good? and will they clear 18's from g35 coupe? also i heard g35 brembo calipers fit 5.5gen...true? with the akebono 370z... im looking at $1k- new calipers, new stoptech rotors, and project MU premium pads... any better ideas?
Old Dec 1, 2014 | 12:33 AM
Fakie J Farkerton's Avatar
6th gen bolts right up.
Just sayin.
Old Dec 1, 2014 | 12:45 AM
www.fastbrakes.com
Old Dec 1, 2014 | 07:33 AM
Prophecy99's Avatar
Just sayin.
6th GEN BBK, is the only thing to say here.
Old Dec 1, 2014 | 07:43 AM
Quickywd01's Avatar
http://www.fastbrakes.com/category_s/51.htm
Old Dec 1, 2014 | 10:59 AM
george__'s Avatar
Holy Maxima lover
Do you own all those Maximas at the moment?
Old Dec 1, 2014 | 12:15 PM
does the 300zx tt calipers fit with out bracket? and still... stock 11.6... 300zx 12.8... 370z 14.0... if read that it should clear the g35 coupe sport 18's by 2mm both top hat and side...
Old Dec 1, 2014 | 12:21 PM
CMax03's Avatar
Bad thing about the Wilwoods are the lack of dust boots since they're more of a track setup they may require maintenace quite often to clean and inspect your pistons, seals, and piston bores for debris and wear!
Old Dec 1, 2014 | 08:19 PM
meh, not really an issue IMO. Many of my fellow SoCal Max enthusiasts having been running these Wilwoods without issue for close to 5 years. Even still, I wouldn't pass up on them because of what you mentioned.
Old Dec 1, 2014 | 09:33 PM
tho ... $650 for 12.6 rotor vs $1,000 for 14.0 rotor? just need bracket for akembono calipers...
Old Dec 2, 2014 | 07:24 AM
Contacted fastbrake and they said if I send them an akebono caliper they can try to make a bracket)
Old Dec 2, 2014 | 07:32 AM
george__'s Avatar
Just do the gen 6 mod and be happy (enough)
Old Dec 2, 2014 | 08:15 AM
I wana go big ... As it is know I over heat all the time... So 6thgen won't cut it.... But I need to find out if the akebono calipers will clear g35 sport 18's.
Old Dec 2, 2014 | 09:43 AM
nestorlugo's Avatar
https://maxima.org/forums/6th-genera...ce-rotors.html
Old Dec 2, 2014 | 02:44 PM
Ya I think the stock ones are 2 piece ... To bad there's no brake upgrade for rear...(
Old Dec 2, 2014 | 03:04 PM
george__'s Avatar
Spend a couple zillion dollars and make one
Old Dec 2, 2014 | 03:45 PM
.... on to the fronts... need to find out if akebono will clear g35 18's...
Old Dec 2, 2014 | 03:56 PM
george__'s Avatar
Reverse engineer something for the rear
Old Dec 2, 2014 | 04:24 PM
The_Fixer's Avatar
There is a wilwood kit with the E-Brake for the max
http://www.fastbrakes.com/product_p/...inch%20kit.htm
Old Dec 2, 2014 | 04:48 PM
Nice but not for $1,300... New 370z akebono calipers with stop tech rotors and project mu pads is $1000...
Old Dec 2, 2014 | 04:49 PM
george__'s Avatar
Thank you
Old Dec 2, 2014 | 07:01 PM
nestorlugo's Avatar
Once again https://maxima.org/forums/advanced-s...de-option.html
Old Dec 2, 2014 | 07:34 PM
Originally Posted by nestorlugo
Old Dec 2, 2014 | 08:36 PM
cdoublejj's Avatar
sunny mild weathered south California? what about the muddy, dusty, snowy, mud covered, hot cold, hot cold Missouri?
this BBK works with stock 16" 5th gen rims?
Old Dec 3, 2014 | 07:15 AM
george__'s Avatar
OP is cheap
Old Dec 3, 2014 | 07:43 AM
nestorlugo's Avatar
OP is cheap
$1000 budget for a bbk on a 5 gen is NOT cheap
Old Dec 3, 2014 | 08:06 AM
george__'s Avatar
yeah it is
Old Dec 3, 2014 | 11:29 AM
yeah it is
i ment for fronts... $1k... but for rears no way max like $500
Old Dec 3, 2014 | 04:52 PM
nestorlugo's Avatar
Dude someone around here (dahood)had two rear z32 calipers for $40 posted on cl 27 days ago i called today (yup) he sold them yesterday
Apr 16, 2020 05:15 AM
Mar 12, 2020 12:06 AM
Robert Schneeweis
Jan 11, 2017 06:47 PM
Redfox
Sep 28, 2015 10:41 AM
Vistance
Sep 17, 2015 05:17 AM
