Car wont accelerate
Old Dec 11, 2014 | 12:14 PM
rkw2012's Avatar
Car wont accelerate
2002 Nissan Maxima GLE If anyone could help me with this problem, It would be greatly appreciated!!! Okay, I bought this car with a timing chain guide noise and recently got it fixed which was the tensioner that was making the sound. Okay before that my car was jerking and hestitating upon acceleration and the codes where at that time P0650, P0032, P0052, and P0430. So after I got the noise fixed, I crunk it up and it didnt rev as it should and when I test drove it, it would not accelerate above 20 mph. I disconnected the battery cable and it would rev up and go but it still jerked upon acceleration but bog right back down to 20 mph and pressing the gas made no difference. The codes I had were p1128, P0032, P0052, P0650, P01122, P0430, P0102, P0113 from what I could remember. So I bought a new MAF and Throttle Body and cleared the codes and only p0650, p1128, p0032, p0052 came back. I drove it for awhile and it was okay but it still jerked but i cleared the codes again and it didnt jerk anymore afterwards. After driving it for about 15 miles, it bog right back down to 20 mph and under. Wouldnt rev as much ( my rpm gauge doesnt work). Got home and reset codes, crunk it up and would rev up fine but it seemed like the car was back hesittating because when I would rev it up and press the gas on the way down it would make a vroom, vroom, vroom, vroom noise. So I took it to a mechanic and he did the relearn procedure (I also did it using the steps without the consult 2 when i replaced the tb and maf but I dont think it worked) but when he did it, it didnt work also. But now that I have gotten it back from him it doesnt rev and only goes 20 mph again. I'm stumped and i dont know what to do.
Old Dec 11, 2014 | 01:43 PM
FanaticMadMax's Avatar
Okay, what you are doing is ignoring those codes based on what you said that you were trying to clear the codes, but it's always going to come back, so you need to focus on what those codes telling you and what possible causes of those fault codes and try to eliminate that. I see too often people just want the light off, in fact when it trying to tell you there is a problem when you are not fixing the possible causes. So you need to start there instead of asking everyone on here, since "we" do not know your car and what kind of issues there, all you can do is go off by the codes and dig deeper trying to isolate the problem. After all, that's what a problem codes are for. Since your post is very vague aside from the timing noise. Your RPM gauge is not working, then you got a sensor is out which is the VSS sensor, P1128 is your TBI , so you didn't indicate if your accelerator pedal TPS is communicating with the TBI since they don't use throttle cable like the pre 2001. as for P0032 and P0052 is have to do with your air/fuel ratio, number of factors, with the O2 sensor, IAT, MAF, MAP and possible vaccum leaks. How many miles does this car has?
Old Dec 11, 2014 | 02:28 PM
george__'s Avatar
Maf
Old Dec 11, 2014 | 05:13 PM
Child_uv_KoRn's Avatar
Bad *** Newb
george is right? What is the world coming to?!?!?!?!?!?
Old Dec 11, 2014 | 05:26 PM
nestorlugo's Avatar
Just to think that 10yrs ago the .org was charging to use the search function !now it gets no love,but searching is boring anyway so we got george_ now!:
Old Dec 11, 2014 | 05:45 PM
george__'s Avatar
I'm right ?
Old Dec 11, 2014 | 07:25 PM
maxiiiboy's Avatar
Originally Posted by rkw2012
2002 Nissan Maxima GLE ........
.... So I bought a new MAF and Throttle Body and cleared the codes and only p0650, p1128, p0032, p0052 came back. I drove it for awhile and it was okay but it still jerked but i cleared the codes again and it didnt jerk anymore afterwards. After driving it for about 15 miles, it bog right back down to 20 mph and under. Wouldnt rev as much ( my rpm gauge doesnt work). Got home and reset codes, crunk it up and would rev up fine but it seemed like the car was back hesitating because when I would rev it up and press the gas on the way down it would make a vroom, vroom, vroom, vroom noise. So I took it to a mechanic and he did the relearn procedure (I also did it using the steps without the consult 2 when i replaced the tb and maf but I dont think it worked) but when he did it, it didnt work also. But now that I have gotten it back from him it doesnt rev and only goes 20 mph again. I'm stumped and i dont know what to do.
You need to focus on your codes. They are telling you this:
  • P0650 - " Malfunction Indicator Lamp Control Circuit"; this code indicates a problem with your CEL light, and more likely, with the associated control circuit.
  • P1128 - "Throttle Control Motor Circuit (TCM) Short"; your TCM motor is faulty, or your TCM harness is open (or shorted), or otherwise messed up. See http://engine-codes.com/p1128_nissan.html for details.
  • P0032 - "Air Fuel Ratio Sensor 1 Heater Bank 1 Control Circuit High;" for details and possible causes, read more at http://engine-codes.com/p0032_nissan-2.html
  • P0052 - "HO2S21 Heater Control Circuit High"; again, see http://engine-codes.com/p0052_nissan.html for possible causes.
You need to address the above codes first. I would start with P1128: I believe that on your car, the TCM is built into the throttle body. Also, It looks like your car is in "limp" (fail-safe) mode. So something failed, hard.
However, given the number and severity of your codes, I wonder whether your ECU is OK. If I were you, I would take the car to the dealer, and I would have them diagnose the problem. Using CONSULT II, they can do it quickly and correctly; they will charge you a fixed fee (about $130 in my neighborhood). That's a good deal. Once they tell you what's wrong, you can decide how to fix the problem - you can do it yourself, or take it to your mechanic, or whatever. Good luck!
FYI, the OBDII codes for 2002 Nissan Maxima are:
P0011 - IVT Control (Bank 1)
P0021 - IVT Control (Bank 2)
P0031 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 1)
P0032 - Heated Oxygen Sensor 1 Heater Low Voltage (Bank 2)
P0037 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 1)
P0038 - Heated Oxygen Sensor 2 Heater Low Voltage (Bank 2)
P0051 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 1)
P0052 - Heated Oxygen Sensor 1 Heater High Voltage (Bank 2)
P0057 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 1)
P0058 - Heated Oxygen Sensor 2 Heater High Voltage (Bank 2)
P0101 - Mass Air Flow Sensor Circuit Range / Performance Problem
P0102 - Mass Air Flow Sensor Circuit Low Input
P0103 - Mass Air Flow Sensor Circuit High Input
P0107 - Absolute Pressor Sensor Circuit Low Input
P0108 - Absolute Pressor Sensor High Input
P0112 - Intake Air Temperature Sensor Circuit Low Input
P0113 - Intake Air Temperature Sensor Circuit High Input
P0117 - Engine Coolant Temperature Sensor Circuit Low Input
P0118 - Engine Coolant Temperature Sensor Circuit High Input
P0122 - Throttle Position Sensor 2 Circuit Low Input
P0123 - Throttle Position Sensor 2 Circuit High Input
P0125 - Insufficient Engine Coolant Temperature For Closed Loop Fuel Control
P0127 - Intake Air Temperature Too High
P0128 - Thermostat Malfunction
P0132 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 1)
P0133 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 1)
P0134 - Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 1)
P0138 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 1)
P0139 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 1)
P0152 - Heated Oxygen Sensor 1 Circuit High Voltage (Bank 2)
P0153 - Heated Oxygen Sensor 1 Circuit Slow Response (Bank 2)
P0154 - Heated Oxygen Sensor 1 Circuit No Activity Detected (Bank 2)
P0158 - Heated Oxygen Sensor 2 Circuit High Voltage (Bank 2)
P0159 - Heated Oxygen Sensor 2 Circuit Slow Response (Bank 2)
P0171 - Fuel Injection System Too Lean (Bank 1)
P0172 - Fuel Injection System Too Rich (Bank 1)
P0174 - Fuel Injection System Too Lean (Bank 2)
P0175 - Fuel Injection System Too Rich (Bank 2)
P0181 - Fuel Tank Temperature Sensor Circuit Range / Performance
P0182 - Fuel Tank Temperature Sensor Low Input
P0183 - Fuel Tank Temperature Sensor High Input
P0221 - Throttle Position Sensor Circuit Range / Performance Problem
P0222 - Throttle Position Sensor 1 Circuit Low Input
P0223 - Throttle Position Sensor 1 Circuit High Input
P0226 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
P0227 - Accelerator Pedal Position Sensor 1 Circuit Low Input
P0228 - Accelerator Pedal Position Sensor 1 Circuit High Input
P0300 - Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfired Detected
P0302 - Cylinder 2 Misfired Detected
P0303 - Cylinder 3 Misfired Detected
P0304 - Cylinder 4 Misfired Detected
P0305 - Cylinder 5 Misfired Detected
P0306 - Cylinder 6 Misfired Detected
P0327 - Knock Sensor Circuit Low Input
P0328 - Knock Sensor Circuit High Input
P0335 - Crankshaft Position Sensor Circuit
P0340 - Camshaft Position Sensor (Phase) Circuit (Bank 1)
P0345 - Camshaft Position Sensor (Phase) Circuit (Bank 2)
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
P0441 - EVAP Control System Incorrect Purge Flow
P0442 - EVAP Control System Small Leak Detected (Negative Pressure)
P0444 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Open
P0445 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Shorted
P0447 - EVAP Canister Vent Control Valve Circuit Open
P0452 - EVAP Control System Pressure Sensor Low Input
P0453 - EVAP Control System Pressure Sensor High Input
P0455 - EVAP Control System Gross Leak
P0456 - EVAP Emission Control System Very Small Leak (Negative Pressure Check)
P0460 - Fuel Level Sensor Circuit Noise
P0461 - Fuel Level Sensor Circuit Range / Performance
P0462 - Fuel Level Sensor Circuit Low Input
P0463 - Fuel Level Sensor Circuit High Input
P0500 - Vehicle Speed Sensor
P0506 - Idle Speed Control System RPM Lower Than Expected
P0507 - Idle Speed Control System RPM Higher Than Expected
P0550 - Power Steering Pressure Sensor Circuit
P0605 - Engine Control Module (ECM)
P0650 - Malfunction Indicator (MIL) Control Circuit
P1065 - ECM Power Supply Circuit
P1102 - Mass Air Flow Sensor Circuit Range / Performance Problem
P1121 - Electric Throttle Control Actuator
P1121 - ABS / TCS Control Unit Performance
P1122 - Electric Throttle Control Performance Problem
P1124 - Throttle Control Motor Relay Circuit Short
P1126 - Throttle Control Motor Relay Circuit Open
P1128 - Throttle Control Motor Relay Circuit Short
P1143 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 1)
P1144 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 1)
P1146 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 1)
P1147 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 1)
P1148 - Closed Loop Control (Bank 1)
P1163 - Heated Oxygen Sensor 1 Lean Shift Monitoring (Bank 2)
P1164 - Heated Oxygen Sensor 1 Rich Shift Monitoring (Bank 2)
P1166 - Heated Oxygen Sensor 2 Minimum Voltage Monitoring (Bank 2)
P1167 - Heated Oxygen Sensor 2 Maximum Voltage Monitoring (Bank 2)
P1168 - Closed Loop Control (Bank 2)
P1212 - ABS / TCS Communication Line
P1217 - Engine Over Temperature
P1223 - Throttle Position Sensor 2 Circuit Low Input
P1224 - Throttle Position Sensor 2 Circuit High Input
P1225 - Closed Throttle Position Learning Performance Problem
P1226 - Closed Throttle Position Learning Performance Problem
P1227 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P1228 - Accelerator Pedal Position Sensor 2 Circuit High Input
P1229 - Sensor Power Supply Circuit Short
P1444 - EVAP Canister Purge Volume Control Solenoid Valve
P1446 - EVAP Canister Vent Control Valve Closed
P1448 - EVAP Canister Vent Control Valve Open
P1456 - EVAP Emission Control System Very Small Leak (Positive Pressure Check)
P1464 - Fuel Level Sensor Circuit Ground Signal
P1490 - Vacuum Cut Valve Bypass Valve Circuit
P1491 - Vacuum Cut Valve Bypass Valve Circuit
P1564 - Automatic Speed Control Device Steering Switch
P1572 - Automatic Speed Control Device Brake Switch
P1574 - Automatic Speed Control Device Vehicle Speed Sensor
P1706 - Park / Neutral Position Switch
P1800 - VIAS Control Solenoid Valve Circuit Open
P1805 - Brake Switch
P2122 - Accelerator Pedal Position Sensor 1 Circuit Low Input
P2123 - Accelerator Pedal Position Sensor 1 Circuit High Input
P2127 - Accelerator Pedal Position Sensor 2 Circuit Low Input
P2128 - Accelerator Pedal Position Sensor 2 Circuit High Input
P2135 - Throttle Position Sensor Circuit Range / Performance Problem
P2138 - Accelerator Pedal Position Sensor Circuit Range / Performance Problem
U1000 - CAN Communication Line
U1001 - CAN Communication Line
Old Dec 11, 2014 | 09:05 PM
ac max 92's Avatar
Wow that's alot of typing lol. May not hurt to make a sticky for a quick reference to those codes for people?
Old Dec 11, 2014 | 09:40 PM
maxiiiboy's Avatar
No, just two clicks - the magic of cut & paste ....
Old Dec 12, 2014 | 05:48 AM
rkw2012's Avatar
Okay, let me make clear. The car is a 2002 Nissan maxima that has 178,780 miles. Everything that I have replaced has been the Throttle body (two of those) and the MAF for this problem. No change. I haven't tried the O2 sensors just yet, but I will soon as I get the car back to the house. I have used 2 throttle bodies and still have received that p1128 code. I have used the search forum but I have yet to see some ppl respond to those that are having similar problems that I have.
Old Dec 12, 2014 | 08:26 AM
maxiiiboy's Avatar
...... I have replaced has been the Throttle body (two of those) and the MAF for this problem. No change. I haven't tried the O2 sensors just yet, but I will soon as I get the car back to the house. I have used 2 throttle bodies and still have received that p1128 code.
That's why I am suggesting you have the dealer diagnose your problem.
It needn't be your Throttle Body at all. What if your ECU is faulty ? You'll be spending a lot of money if you just keep throwing parts at the problem ......
Old Dec 12, 2014 | 12:57 PM
Originally Posted by maxiiiboy
That's why I am suggesting you have the dealer diagnose the problem.
I needn't be your Throttle Body at all. What if you ECU is faulty ? You'll spend a lot of money if you just keep throwing parts at the problem ......
I second that, since replacing the same thing over and over is not really solving the problem and definite waste of money and time.
Old Dec 12, 2014 | 03:19 PM
nestorlugo's Avatar
i should just add it to my sig.
Old Dec 12, 2014 | 03:26 PM
foodmanry's Avatar
Da Roller Coaster!
Step in the gas, not the brake.
Old Dec 12, 2014 | 05:52 PM
QueensMAX's Avatar
Check your ECU for burnt chips.. Came across a 2003 maxima with a shorted out engine mount that burnt a chip on the ECU. I had the MIL indictator light code as well.
Old Dec 13, 2014 | 11:10 AM
rkw2012's Avatar
I'm sorry maximal that was for the first person that replied. As for your advice I'm going to take it to Nissan Monday morning. But I have checked when pressing the gas, the throttle doesnt respond so it's not opening. And I have checked the ecu, it has something moving inside, I opened it and it was some kind of chip that came off one of three black things in the middle.
Old Dec 13, 2014 | 11:23 AM
george__'s Avatar
Go find another ECU
www.car-parts.com
Old Dec 13, 2014 | 12:05 PM
maxiiiboy's Avatar
OK, it looks like your ECU is damaged; the moving "thing" inside is a burnt chip, probably one of the chips driving your Engine Mounts and/or IACV. It is well documented on this forum that when these parts fail, they usually damage the ECU.
You have a significant problem. To fix the car, you will need to do the following:
  1. ECU. You'll have to fix or replace your ECU. There are many ways to do it, more about that later. However, when you get your new/fixed ECU, do not plug it in !! Before you do that, you must first fix/replace the part that caused the ECU damage (or, it will do it again, it has happened to people on this forum). It is well known and documented here that failures of the IACV (Idle Air Control Valve) and/or of Electronic Engine Mounts do damage ECUs.
  2. IACV. If your IACV failed, you need to replace it. If it hasn't failed yet, you may want to implement some sort of preventative measure such as "Coolant Bypass (search for howto).
  3. Electronic Engine Mounts. On Maximas with AT, the Front and Rear engine mounts are electronic. When they fail, they can, and usually do, damage the ECU. In this case, here is a simple preventative measure - disconnect them. Again, use search for how to do this.
    EDIT 12/13/2014: In fact, if your mounts go short, they may damage both your ECU and your IACV. See this post: https://maxima.org/forums/5th-genera...ml#post6937118 .
I would still take your car to the dealer and have it diagnose it (for the fixed fee). My guess is that the dealer will quote at least $2k to fix it. You can do it yourself for less, but it will take some effort.
It's a pity you spent money on replacing your TB (twice!) - I don't think it was the cause of your problems.
Old Dec 13, 2014 | 12:07 PM
george__'s Avatar
how fragile these car are
Old Dec 13, 2014 | 12:20 PM
maxiiiboy's Avatar
Actually, its just extremely poor engineering by Nissan. I don't understand why they did not protect the ECU by inserting fuses or electronic circuit breakers into these critical connections. It's almost criminal negligence .....
Old Dec 13, 2014 | 12:24 PM
george__'s Avatar
Like 60% of aftermarket parts on these cars seem to fail if aftermarket too
Old Dec 13, 2014 | 12:58 PM
Jprocs24's Avatar
I've been told to replace with OEM if possible, Maxi's are picky.
Old Dec 13, 2014 | 01:12 PM
rkw2012's Avatar
Okay, I have spare ecu. In my area it's 45-90 an hour for diagnostic. It shouldn't take that long would it?
Old Dec 13, 2014 | 01:35 PM
maxiiiboy's Avatar
Nissan dealers usually do it for a fixed fee. You need to ask your dealer. And have him diagnose all possible problems - as I am sure you have more than one. Basically, you want him to identify all parts that are bad, not just the first one. This can only be done with Consult II - the Nissan diagnostic tool.
BTW, I assume that you know that when you replace your ECU (rather than fixing it), you'll have to have your car keys reprogrammed.
Old Dec 13, 2014 | 05:49 PM
rkw2012's Avatar
Yes, I know a friend told me awhile ago. But I'll have to call and see cause I do remember them saying 45-90 an hour when they did my crankshaft replacement for free when I had another problem (just a blown fuse). But thank you all for your help!
Old Dec 14, 2014 | 08:27 AM
rkw2012's Avatar
Where is the idle air control valve and motor mounts on this car? Car won't even crank now.
Old Dec 14, 2014 | 10:16 AM
maxiiiboy's Avatar
The IACV is mounted on the Throttle Body. You have to remove the air box to get to it.
The Electronic Mounts are mounted on the cross-member. However, the two connectors for the engine mounts are accessible from above. They are brown, and close to the AT dipstick. The connector numbers are F23 (front) and F9 (rear) - this is on my car (2000 SE).
Do you have the FSM (factory Service Manual) for your car? You can download it from here: http://www.nicoclub.com/archives/nis...e-manuals.html
Old Dec 14, 2014 | 10:49 AM
rkw2012's Avatar
Okay so I've tried to find the iacv but I guess my car doesn't have one it's a 2002, it's not connected to the throttle body.
Old Dec 14, 2014 | 11:01 AM
maxiiiboy's Avatar
It certainly does .... download the FSM for your car and look it up. Moreover, most part supplier sell it.
However, first get the diagnosis done at your dealer as I suggested earlier!
Correction: You are right, the 2002 and fwd does not have the IACV.
Lakersallday24
Jun 16, 2019 01:35 AM
scarletsosa
Aug 17, 2015 09:09 PM
Stagnet04
Aug 16, 2015 11:15 PM
Bruceharrison
Aug 9, 2015 07:56 AM
Gsantos79
Aug 8, 2015 07:41 AM
