Built-in Self Diagnosis ?
Old Dec 19, 2014 | 02:54 PM
acw's Avatar
acw
Hey Buds,
I was reading on the 6th generation site, that there is a "diagnosis program" that runs on the Radio of the Car.
Do the 5th gen Max. have the same option?
IF so...how do i get there?
Is there anyway to check the A/C system through a plug in diagnosis meter?
Thanks for any help...
~T
Old Dec 19, 2014 | 04:51 PM
george__'s Avatar
I don't think so
Check the FSM, there could be another way to test it
http://www.nicoclub.com/archives/nis...e-manuals.html
Old Dec 19, 2014 | 05:29 PM
acw's Avatar
acw
Yeah George...i don't think so either.
Apparently only certain MODELS of Nissan cars had that feature in their RADIO setup.
Nico site has been a waste of time on this issue.
thanks!
Old Dec 20, 2014 | 01:26 AM
DennisMik's Avatar
The auto climate control version of the heater/ac has a self diagnostic for the ac.
What year is your car and does it have to auto climate controls?
Old Dec 20, 2014 | 04:38 AM
acw's Avatar
acw
Dennis....i have a 2003 Infiniti I-35. It is basically the same setup as the 03 maxima.
There is an auto climate control button....yes. Is that what you are referring to?
  • How do i get to the DIAGNOSIS mode?
  • The Car has heat, so if i turn the theromstat control to Heat, i get hot air. But it doesn't get cold enough. I suspect a leak somewhere, since i just changed the compressor 2 mths ago.
....Thanks !
Old Dec 21, 2014 | 12:58 PM
DennisMik's Avatar
Since you have an Infiniti, you don't have manual controls. Infiniti only used the auto climate controls.
To run the self diagnostic, go to page 36 in this link:
http://boredmder.com/FSMs/Infiniti/I35/2003/HA.pdf
Since you changed the compressor, it is possible that you may not have enough R134A refrigerant in the system. If this were to be the case, the self diagnostic cannot detect it. If the refrigerant level gets too low, there is a pressure sensing switch that will keep the compressor from running.
The self diagnostic checks all the duct work and sensors and stuff. There are 4 (?) temperature sensors in the system which could also cause the problem. When you run the diagnostic, make sure you know what the air temperature is around the car so you can compare to the reported sensor readings (part 5).
One of the sections of the self diagnostics (part 3 I think) of the test takes a while to run, so don't start thinking the diagnostic hung up or something.
Old Dec 22, 2014 | 06:17 AM
acw's Avatar
acw
Thanks Dennis...
  • -Compressor is turning, and clutch is turning.
  • -Changed Compressor & Condensor about 2mths ago....was blowing cold when i changed it
  • -I suspect a leak somewhere...(hope it is not the Evaporator)
I will take your advice...and follow those steps...Thank you!
~T
Old Dec 22, 2014 | 06:56 AM
acw's Avatar
acw
OK the Sensor test came back good.
Suspect a leak somewhere....
jcvgn
Sep 10, 2015 08:03 PM
dougiestares
Apr 3, 2002 10:42 AM
yongjun
Feb 27, 2002 12:27 PM
r0bilikewh0a
Jan 16, 2002 11:31 AM
Ginuwin3112
Jan 2, 2002 06:34 PM
