Trembling car
Old Dec 23, 2014 | 09:14 PM
egali045's Avatar
Trembling car
So today I turned on my car and as I drove for about 5 mins, it began to shake/ trembled and the CEL light began to blink for like 10 secs. Anyone know what's going on?
Old Dec 23, 2014 | 10:58 PM
Cotozic's Avatar
I think a blinking CEL means a cylinder is misfiring.
I'd be sure to check your CEL codes and go from there.
Do any work to your car recently?
Old Dec 23, 2014 | 11:29 PM
tosheto's Avatar
^ What he said. It is misfire and you need to check the codes.
Old Dec 23, 2014 | 11:42 PM
AEKnight's Avatar
More than likely a bad coil causing the misfire.
Old Dec 24, 2014 | 12:53 AM
Maxima_02's Avatar
snowed in
i was just about to make the same post haha. my Nissan has been doing the same thing. The first time i got the code i was told it was cylinder 6 that was misfiring but they told me it didn't say if it was the ignition coil or the spark plug so he told me switch the coils and check the codes again. i did but then it was cylinder 2 but i never touched cylinder 2 just 6 and 4 if im correct. i got the codes again and it said cylinder misfire again but it didnt give me a number (and this was the 3rd time i check the codes). i dont know what to do now.
Edit: mine only trembles when i slowly step off the brake, as if i was at a red light and getting rdy for it to change. On the freeway it drives smooth and the check engine light starts flashing around 50+ mph
Old Dec 24, 2014 | 05:59 AM
TallTom's Avatar
If your car has around 100k miles and you never changed the plugs yet, I would do them first for 6 plugs cost less than one coil.
Old Dec 24, 2014 | 10:28 AM
egali045's Avatar
Just seen spark plugs are covered with oil. Not sure if oil affects coils. Problem detected
Old Dec 24, 2014 | 10:38 AM
george__'s Avatar
Fix up the valve covers using the GENERATION 6 NISSAN MAXIMA (2004+) with gaskets.. You could technically leave the front alone but up to you. Rear for sure replace though
While you are back there change up the ignition coils to new HITACHI or new OEM. Don't use other brands.
Did you fry your engine?
Old Dec 24, 2014 | 02:42 PM
edwardh1's Avatar
agree , NAPA coils on mine (from china) put on by a garage ran fine but threw a cel. The garage went and got oem no problem.
Old Dec 28, 2014 | 06:16 PM
egali045's Avatar
Update
So i replaced valve covers ! And new spark plugs ngk laser. But still trembles a little. So how can find out which coil is bad? Do 2000-2001 fit 2002?
Old Dec 29, 2014 | 02:42 PM
Mateen995's Avatar
you can swap them around with a different coils to see if your misfire moves.
I had a misfire on the 5th cylinder but had to do spark plugs soon anyways so I replaced all 3 rear coils as well as a valve cover.
my 5th cylinder spark plug was covered in oil, as well as the coil boot
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
