15" 300ZX (1st gen) Wheel Fitmnet
Old Jan 24, 2002 | 08:26 AM
DPDISXR4Ti's Avatar
Does anyone know if these wheels will fit on a 5th gen Maxima? Note, these wheels only came on the ZX Turbo, as the NA cars still used the 4 lug wheels. I was thinking about gabbing them from the JY for snow tire wheels. I know the bolt pattern is correct (5 x 4.5"), but not sure about offset, hub size, or possible clearance problem with caliper. Any thoughts?
Thanks,
Brad
Old Jan 24, 2002 | 10:55 AM
BigDogJonx's Avatar
Re: 15" 300ZX (1st gen) Wheel Fitmnet
Thanks,
Brad
4 Lug bolt pattern: 4x4.5(4x114.3)
5 Lug bolt pattern: 5x4.5(5x114.3)
Studs are m12x1.25
Centerbore is 66.1mm
Stock wheel offset:
84-85 all(except AE): 30mm
86 non-turbo: 10mm
86 turbo: 20mm
87-89 Turbo: 30mm
87-89 non-turbo: 20mm
The stock tire size is 215-60-15 on 15x6.5 wheels, and 225-50-16 on the 16x7 wheels.
So the offset is incorrect for the answer to your question, the wheel will stick out almost 1" more out. This might very well will cause wheel well rubbing when you hit potholes or when you pack too many people in the car.
I know cause I did this on my 98 Millenia, I got the wrong offset and the wheels stuck out, not like so far that it was OUTSIDE of the fender, more like just enough so that when the wheel goes up into the wheel well, it would rub the outer side of the inside wheel well.
Dixit
Old Jan 24, 2002 | 11:17 AM
DPDISXR4Ti's Avatar
Re: Re: 15" 300ZX (1st gen) Wheel Fitmnet
Studs are m12x1.25
Stock wheel offset:
86 non-turbo: 10mm
86 turbo: 20mm
87-89 Turbo: 30mm
Dixit
Thanks for the info - I guess you know something about Z's, huh? <g>
Do you know if the Maxima centerbore is also 66.1mm? Since these would be snow tires wheels, I'd get skinnier, taller tires, so I might be okay clearance-wise. Of the wheels you've posted above, do you know what size (15 or 16) and bolt-hole count (4 or 5) they are? I'm sure the 30mm offset wheels would be fine since that's only 10mm different than stock.
BTW, how do you attach JPEG's here? I have a picture of the wheels I'm looking at.
Thanks again,
Brad
Old Jan 24, 2002 | 11:53 AM
BigDogJonx's Avatar
84ae. 5 lug, 16x7
84-85 non turbo. 4 lug, 15x6.5
84-85 turbo. 5 lug, 15x6.5
86 non turbo. 5 lug, 15x6.5
86 turbo. 5 lug, 16x7
87-89 non turbo. 5 lug, 15x6.5
87 turbo. 5 lug, 16x7, black tinted clearcoat
88se. 5 lug, 16x7, painted white
88-89 turbo. 5 lug, 16x7
I dont have time to post each and every picture of each one, but i can get it if you need. Hope this helps.
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
criminalslang810
Aug 16, 2015 08:12 AM
