2003 maxima electric issue pls help!
Old Jan 20, 2015 | 07:09 PM
Stallion12's Avatar
Whats up guys im new here and im having a problem with my car, tried searching but couldnt find anything. This morning i swapped the full cloth interior (door panels and seats) of my 03 maxima to leather imterior from a 2000 maxima. After the swap my power seats/ lock buttons/windows/remote dont work. After disconnecting the batery for a few minutes the power options work but then stop within 1 second. Any help would be appreciated.
Old Jan 20, 2015 | 09:02 PM
Cotozic's Avatar
Did you try seeing if the original equipment functions normally if you hook it back up?
Old Jan 20, 2015 | 09:53 PM
shawniiebwoiiee's Avatar
I have a 2000 maxima I had a electrical issue when I first baught the car that the 40 amp fuse kept lowing because the power wire on my driver side seat kept grounding out . basically every time I'd pull the fuse out and let the circuit breaker die out and put the fuse back in it will work . so what id if I was you check the 40 amp fuse in the driver side fuse box next to the battery next to the fender make sure it's good ( fuse controls power Seats ,windows , sunroof ,alarm ,door lock).and unbolt the seat to see if the wire for the switch on the seats aren't rubbing/grinding on the metal seat tracks . on my car i didn't remove my seat because it was freezing like around this time of the year . what I did was Pop out the switch on my driver seat and it was a ***** because I only had the car for a week and I didn't want to break anything , so basically see if the switch wires are grounding out on the metal tracks . I'd say remove the seat because I broke a piece of my switch but I zip tied it and it's been working great to far .
now I don't know which seat it is that's giving you a problem but the way I figured out was I found my answer on the org last year .but the reason why I checked the driver side is because everytime if sit down on the seat I hear something shorting like buzz sound( power grounding out) I kept bouncing on it to make sure (no homo) . keep me updated
I think this is the thread I used , take my advice
https://maxima.org/forums/5th-genera...me-advice.html
Old Jan 21, 2015 | 12:36 PM
DennisMik's Avatar
Are you using the power window switch that came with the car? Each year of the car requires a different power window switch.
Old Jan 21, 2015 | 08:12 PM
Stallion12's Avatar
I haven't as I don't have the original seats anymore.
Old Jan 21, 2015 | 08:14 PM
Stallion12's Avatar
Thanks for the response I'll try to take off the seat tomorrow and see if it's grounding out, and how do I check if the 40 amp fuse is good?
Old Jan 21, 2015 | 08:16 PM
Stallion12's Avatar
Yes all the switches are original and we're in working condition before the swap.
Old Jan 21, 2015 | 08:54 PM
you can see it when you remove it from the fuse box but it's not that visible because the fuse looks weird I just baught one to be safe
Old Jan 22, 2015 | 08:50 AM
Stallion12's Avatar
Ill be checking up on it today after work, and ill keep you guys posted
Old Jan 22, 2015 | 04:34 PM
Max_5gen's Avatar
... After the swap my power seats/ lock buttons/windows/remote dont work. After disconnecting the batery for a few minutes the power options work but then stop within 1 second. Any help would be appreciated.
Can you elaborate- how do they work for 1 sec? Does this happen only after you disconnect/reconnect battery? Does your dome light work?
Old Jan 23, 2015 | 11:23 AM
Brutalboo's Avatar
Hey man. had the same problem on new years. near the peddles should be alittle black box. should say 12v. if you cant find it ill take a pic when i have my car.
Old Jan 23, 2015 | 12:53 PM
Stallion12's Avatar
It would start moving then stop soon as I reconnect the battery
Old Jan 23, 2015 | 12:54 PM
Stallion12's Avatar
Is it a module? Or what is it? What does it control?
Old Jan 23, 2015 | 08:43 PM
no solution so far bro ?did u check the harness I mentioned
I'm thinking he's talking about the circuit breaker I could be wrong tho
Old Jan 25, 2015 | 10:57 AM
Stallion12's Avatar
I can't locate the box ur talking about, can someone post a pic of what it looks like?
Old Jan 26, 2015 | 04:05 AM
ok it's at the end of the intake ,next to the battery . between the battery and the driver side fender . should say power locks or something
Old Jan 26, 2015 | 10:13 AM
DennisMik's Avatar
Somebody takes care of their car! Looks nice.
Old Jan 26, 2015 | 01:47 PM
Stallion12's Avatar
I'll be trying that tonight as I have a second maxima I can switch of parts. I'll keep you guys posted.
Old Jan 27, 2015 | 10:27 PM
https://maxima.org/forums/5th-genera...p-working.html
Old Jan 27, 2015 | 11:59 PM
Max_5gen's Avatar
Interesting- if one of the circuits connected to circuit breaker overloads it SECU would lose its power supply leadin to failure of all those functions. I'd begin disconnecting things powered through E90 circuit breaker starting from power seats and checking if that helped.
Slamrod
Apr 10, 2016 05:24 PM
ah2002
Mar 9, 2016 01:42 PM
wingsfan24
Aug 15, 2015 07:35 PM
Samedi
Aug 13, 2015 04:05 PM
09maxshawn11
Aug 9, 2015 01:13 PM
