Strange sound
Old 01-20-2015, 09:16 PM
egali045's Avatar
Strange sound
Any one know why I hear like a tap noise everytime i hit a bump at a slow speed. Sounds like im riding it with the front hood Not properly closed all the way. Or It kinda sounds like a bad strut but i know it is not because i just replaced it. It sounds like something is loose. I thought it was the axle but it is not neither the suspension accordinng to the mechanic. the sound comes from my side in the front. Any one know what kind of noise im talking about.
egali045 is offline
Old 01-20-2015, 09:21 PM
nestorlugo's Avatar
Tranny mount or hood stopper has disintegrated...my top guess
nestorlugo is offline
Old 01-21-2015, 06:42 AM
Carguy1709's Avatar
Does your rad support have rust? The hood latch couldve disconnected from it. Maybe the swah bar links that comnect to the lower control arms could be bad. I think thats what there called lol. Good luck!
Carguy1709 is offline
Old 01-21-2015, 09:08 AM
BLOMAX44's Avatar
tapping noise
a tapping noise suggest a small part worn, or loose. start by driving on a smooth road to determine if its really front or rear, top or bottom, then the fun begins get your gloves have this vehicle raised on a "strait rack" one that lifts the vehicle by the wheels as if it was on the ground. then start grabbing and shaking all suspension parts, don't be shy grab with with your hands and shake any rattling you find "investigate" it as a potiential problem until you know its "normal" movment.
rule if it makes the same noise regardless of vehicle stop and go, pitch and roll, its most likely in the body
if it's reacts to those things including speed it's most likley in the suspension, have fun.
BLOMAX44 is offline
Old 01-21-2015, 09:12 AM
Ben2003GLE's Avatar
check your passenger side mount
Ben2003GLE is offline
Old 01-21-2015, 11:16 AM
egali045's Avatar
That's what the mechanic did. I took it to the shop and i had told them about the problem and they checked for loose suspensions. They said they couldn't find the problem. They even took it for a ride. So im guessing its either transmission mount or rad support.
How can i check to make sure?
I am not sure. Around what part should there be rust? And the sway bar links was replaced 2 months ago so im sure it can't be that.
egali045 is offline
Old 01-21-2015, 05:42 PM
Carguy1709's Avatar
Look at the bottom of the radiator. You will see the bottom of the front rad support. In which there is a motor mount right in the middle. See if there is rust, it could be that the motor mout seperated. Ive seen it before lol not pleasent
Old 01-21-2015, 06:16 PM
IsaacFall's Avatar
The same thing happens to my car. I'm installing coilovers and all new mounts in the front and back, so I'm curious to see if that will have any effect on the noise.
IsaacFall is offline
Old 01-22-2015, 07:35 PM
egali045's Avatar
I think it's the cooling fan. Iwas able to wobble it. It was loose. But how? Right now i tied it with a rope, let's see tomorrow how it goes.
egali045 is offline
Old 01-22-2015, 07:40 PM
egali045's Avatar
Lucky. Mines are Unity. :/
egali045 is offline
Old 01-22-2015, 07:49 PM
nestorlugo's Avatar
There's two tabs on the bottom of the fans that slide into some slots on the radiator,while the top is fastened with two bolts one is visible and the other is under the air scoop.
Old 01-23-2015, 07:41 AM
egali045's Avatar
Guys guys iknow what the problem is. It has to deal with the hood. Right now it is all the way close but i could squueze my fingers n try to wiggle it up and down and it's that noise. Now since i tied the cooling fan yesterday, top part. The noise got worse, in the highway i thought i didnt close the hood right but when ifinished driving i checked and it was close! So what's causing this problem? Where can i look
egali045 is offline
Old 01-23-2015, 07:45 AM
egali045's Avatar
Oh and it is on my side and a little on the passenger
egali045 is offline
Old 01-23-2015, 08:05 AM
nestorlugo's Avatar
Check the hood stoppers ....look at the plastic piece between the two bolts it might have disintegrated Name:  CAM00567_zpso8utwe28.jpg
Old 01-23-2015, 09:49 AM
egali045's Avatar
isn't there like a little stick sticking out ? what can I do? Is it easy to replace?
egali045 is offline
Old 01-23-2015, 09:52 AM
egali045's Avatar
where can i get those rubbers??
egali045 is offline
Old 01-23-2015, 10:12 AM
maxiiiboy's Avatar
+1 !
Check it out - run you finger along both rubber surfaces, check for cracks.
maxiiiboy is offline
Old 01-23-2015, 10:28 AM
egali045's Avatar
Originally Posted by maxiiiboy
+1 !
It does have cracks all around it.
egali045 is offline
Old 01-23-2015, 10:47 AM
maxiiiboy's Avatar
Well, here may be your problem (or one of your problems). I should just note that the mount does not have a completely smooth surface. See the pictures below.
If your car has an AT, this is how a good mount should look like; http://www.rockauto.com/info/17/EM-9251.jpg . You can buy it fairly inexpensively from RockAuto.com.
If you have an MT, the mount looks like this http://www.rockauto.com/info/60/A7304.jpg . However, they are interchangeable; I have used an "MT" mount on my "AT" car without any problems.
Old 01-23-2015, 11:23 AM
nestorlugo's Avatar
I got them from the junk yard but the dealer or courtesy nissan should have them...i got an extra set if you're interested...
Try to wedge something like cardboard and close the hood...go for a drive and see if it goes away....is not then proceed to check the mounts...
Old 01-23-2015, 11:25 AM
egali045's Avatar
If you have an MT, the mount looks like this http://www.rockauto.com/catalog/imag...spurple100.png . However, they are interchangeable; I have used an "MT" mount on my "AT" car without any problems.
but isn't this for the transmission mount? Is this what keeps the hood sturdy?
Because I have a automatic transmission.
egali045 is offline
Old 01-23-2015, 12:21 PM
colt149's Avatar
I had it before on my 2002 maxima. The culprit is the hood latch, I replace the two adjustable rubber (L & R )support that prevent hood vibration. Replace the small rubber in the middle tip of the hood near the latch catch. I also place 3 layers ofh electrical tape on the hood catch,so the latch will lock firmly. Problem solve.
colt149 is offline
Old 01-23-2015, 02:31 PM
egali045's Avatar
Where were you able to get the rubber? I definitely will get them! and will tape them bRitches good. Problem coming to an end finally lol YAY
egali045 is offline
Old 01-23-2015, 07:02 PM
colt149's Avatar
Courtesyparts.com
colt149 is offline
Old 01-24-2015, 02:51 PM
egali045's Avatar
Problem solved!
Bought electric tape. Taped around a gap of the rubber as I was pulling it up taped it to the size of the rubber! It only had 2 in the front. Noise stopped as im driving.
egali045 is offline
tarun900
19
12-20-2021 06:57 PM
AaronL
08-08-2020 10:31 AM
Mahmuth
10-17-2015 12:03 PM
Need help
23
10-02-2015 08:56 AM
DC_Juggernaut
09-28-2015 04:07 PM
Quick Reply: Strange sound
