i need the PRCAI template...
if anyone can scan me a copy of the template, or help me out somehow, i'd really appreciate it.
i called place racing twice and asked them to fax it to me, but they never do. i've tried dry fitting it and then seeing where the hole will be, but that's not working, cause the pipe is too long and some of it goes through the hole.
help me, please......
Originally posted by victor
hmm, i could always try again. when you winged it did it fit??
your tempting me to wing it also. but i don't want to have to keep on cutting holes till it fits. lol.
you pull everything out.. clean clean engine bay..
then you run the piping.. you know the piping goes down about 3 inches in the hole..
you line it up.. since you don't have everythign tightned you can flex the pipe all you want to.. put as best you see fit for it to go in the hole.. mark that off with a marker.. razor anything you can see.. and then cut away..
if not.. try PR again..
give me the number.. i will call them since i have a personal fax number.. then get it for you.. if not then you try to wing it..
Originally posted by BigDogJonx
Do a search, someone attached the scan of the template like 3months ago.
I have the file at home, not here on my work computer.
Dixit
Dixit
Originally posted by SprintMax
she says she is faxing it to me.. i will get back to you.. don't move
They must love me
right click and save as..
template was here
i converted it to gif but it was too big.. i can fax it to you also
template was here
so you viewed it ok? if so no prob..
then i started to get to work making the hole. not as easy as i thought making that hole, pretty tight little space to work with.
i got it in in an hour after you posted. i had to rush it a little. it all fits good, only thing is i forgot to put the rubber thing around the hole, i'll have to take it out and redo that part.
dude, thank you so much.
yup. i got it. it didn't fit when i printed it directly, so i had to resize it a couple times before it would fit close.
Paradoxish
May 2, 2002 11:19 AM
Snoop
Mar 4, 2002 05:00 PM
Y2KevSE
62
Mar 3, 2002 05:04 PM
sleepermax
Feb 11, 2002 02:36 PM
