Exhaust flow....
^ I concur. Pretty sure that's why my car stinks at WOT, despite the ypipe and gutted cat and intake/exhaust and all. You'd think it breathes so much better and would be more lean but nope it still dumps too much fuel at WOT.
I need a tune...
I need a tune...
Nope, the MAF is used for that (AFR’s). O2’s pretty much take care of idle and anything below 25 MPH and VERY low throttle angles. If we’ve learned anything in the past 15 years it’s that these are terribly rich from the factory as it is and still require AFR tuning even in stock form, even more so when modified.
I noticed today that it IS in fact right after slowing down from WOT that I smell the fumes in the cabin...lol
My exhaust is actually unsupported between my y pipe and the muffler hangers..lol. It's bolted so tight though it's like one piece. If I get the resonator welded in I'll have em fab a hanger if they think it needs one..
*correction..the b pipe has a hanger...lol
So you do have a hangar stud welded on the Ypipe right? Cause the OEM exhaust has the hangar mount @ the ypipe then the next hangar mount is after the resonator!
Nope...but I will have one put on by the exhaust guy if he thinks I need one when I get the glass pack welded in. The y pipe came with a nice hanger, but the way it's supposed to work is virtually useless. Thankfully the back of the y pipe is bolted straight up to the manifold so it's really solid. Not much movement at all from the test pipe to the next hanger back.
Just to clear up possible confusion. I have either a thrush or cherrybomb glasspack as the resonator. There are no louvers inside it... Guaranteed. Straight-thru design with perforated core tube. im running no muffler, stock ypipe with non-gutted precats, and main cat...sounds throaty, no rasp, but drone between 1800 and 2200 rpms. Partly due to the idiot who welded my exhaust.
Sorry for bump from the past but..
I had my brother drive my max while I drove his car to hear what my exhaust sounded like and boy.. I didn't realize how raspy my baby sounded until he WOT it.
I believe the stock muffler inlet is 2"? How is it that 2.5" piping works well with the 2" muffler?
(Address performance question then the rasp please
Generally, the bigger the resonator or muffler, the less the rasp. The OEM mufflers are giant, so that would probably eliminate all of the rasp, but It will also quiet it down quite a bit. If you like your exhaust loud, then you might want to look in to getting a bigger resonator instead of the OEM muffler.
I'm probably going to be disappointed but there's only one way to figure it out.
LOL.. don't get your hopes up.. what's your exhaust system like?
