Flooded 00 maxima
Old Mar 8, 2015 | 07:10 AM
Cx1's Avatar
Cx1
Flooded 00 maxima
I need help getting this car to run
Old Mar 8, 2015 | 09:30 AM
nestorlugo's Avatar
Year? Mileage? Recent work? Running history?
Old Mar 8, 2015 | 10:13 AM
DennisMik's Avatar
Old Mar 8, 2015 | 10:36 AM
Cx1's Avatar
Cx1
2000 with 130k , I've changed fuel pressure regulator, MAF , throttle body
Old Mar 8, 2015 | 11:19 AM
Donkeypunch's Avatar
Is it even sparking?
Old Mar 9, 2015 | 06:14 AM
Cx1's Avatar
Cx1
the Sparks get wet immediately
Old Mar 9, 2015 | 03:30 PM
Y2kMaxima's Avatar
Injectors...?
Old Mar 9, 2015 | 03:31 PM
DennisMik's Avatar
Do you mean the spark plugs? If so, you could have some bad fuel injectors or the o-rings that seal them.
Old Mar 10, 2015 | 06:36 AM
Cx1's Avatar
Cx1
one injector seems to have a lot of pressure
Old Mar 10, 2015 | 01:19 PM
DennisMik's Avatar
All injectors have the same pressure supplied to them. Comes from the fuel pump and the fuel pressure regulators.
If one injector seems to be "injecting" too much gas, then it is the injector or the o-rings.
However, just one or two, maybe 3 bad injectors won't stop the engine from starting. There may be other problems also.
Old Mar 10, 2015 | 04:32 PM
Cx1's Avatar
Cx1
All injectors have the same pressure supplied to them. Comes from the fuel pump and the fuel pressure regulators. If one injector seems to be "injecting" too much gas, then it is the injector or the o-rings. However, just one or two, maybe 3 bad injectors won't stop the engine from starting. There may be other problems also.
True it should turn . Fyi we also replaced the air intake gasket , fuel pressure regulator, throttle body, MAF and i don't know if this could also affect it but the previous owner put in a 03 ECU
Old Mar 10, 2015 | 07:43 PM
cornholio's Avatar
im surprised this ever worked. did previous owner swap in a vq35? i'd think the cars are too different otherwise
Old Mar 11, 2015 | 05:28 AM
Cx1's Avatar
Cx1
No it has original 3.5 engine
Old Mar 11, 2015 | 05:29 AM
Cx1's Avatar
Cx1
It's original ECU won't run the fuel pump
Old Mar 11, 2015 | 08:44 AM
nestorlugo's Avatar
2000 maximas didn't have 3.5 engines
Old Mar 11, 2015 | 09:17 AM
Cx1's Avatar
Cx1
Oh It doesn't? I checked to make sure , it says v6 3000
Old Mar 11, 2015 | 09:18 AM
Cx1's Avatar
Cx1
So it's 3.0?
Old Mar 11, 2015 | 11:36 AM
cornholio's Avatar
Old Mar 11, 2015 | 10:02 PM
DennisMik's Avatar
The crankshaft sensor and the camshaft sensor systems are different between the 3.0 and 3.5 engines so the ECU isn't getting the signals it wants.
But the original ECU not running the fuel pump is very unusual, although possible. Did you get the original ECU?
Why was all the other work done? Was this done trying to get the car to start befor aor after the ECU swap?
Old Mar 12, 2015 | 06:39 AM
Cx1's Avatar
Cx1
The crankshaft sensor and the camshaft sensor systems are different between the 3.0 and 3.5 engines so the ECU isn't getting the signals it wants. But the original ECU not running the fuel pump is very unusual, although possible. Did you get the original ECU? Why was all the other work done? Was this done trying to get the car to start befor aor after the ECU swap?
The previous owner swapped the ECU that was from an 03. All the work was done with the 03 ECU. We changed the throttle positioning sensor and MAF because it was giving us erratic rpm
Old Mar 12, 2015 | 02:41 PM
DennisMik's Avatar
It sounds like the car may have a bad IACV (Intake Air Control Valve) and this has a tendency to short out integrated circuits in the ECU.
But you have to get a 2000 ECU for you car - PERIOD. No ifs ands or buts.
And before you hook up the 2000 ECU test out the IACV as outlined in the service manual on pages 502 and 506 in the link below.
http://boredmder.com/FSMs/Nissan/Maxima/2000.5/EC.pdf
Old Mar 12, 2015 | 02:45 PM
You can't run an 03 ECU on your 00 Max and expect everything to run right. Get the proper 00 ECU. This should be the very first thing you do.
Old Mar 12, 2015 | 04:57 PM
Cx1's Avatar
Cx1
I'll try to find one that's compatible
I just got it to run but then it stopped, checked the spark plugs and the tips were wet and kinda looks like oil
Old Mar 12, 2015 | 07:51 PM
DennisMik's Avatar
I don't know how the spark plugs could have oil on them without the engine having serious mechanical damage.
The next time you take the plug out, smell it. Does it smell like gas or oil?
Old Mar 13, 2015 | 05:06 AM
Cx1's Avatar
Cx1
I don't know how the spark plugs could have oil on them without the engine having serious mechanical damage. The next time you take the plug out, smell it. Does it smell like gas or oil?
It smells like gas but the tip is covered black
Old Mar 13, 2015 | 12:06 PM
Which mean it's running really rich, because of the wrong ECU.
Install proper ECU
Install new plugs
Then we'll take it from there.
Old Mar 13, 2015 | 03:48 PM
DennisMik's Avatar
At the risk of repeating my self...
Old Mar 13, 2015 | 06:49 PM
Cx1's Avatar
Cx1
We are going to get a new ECU
I know this is off topic but does anyone know why the dashboard lights stay on for a few seconds after taking the key out
Old Mar 13, 2015 | 07:00 PM
nestorlugo's Avatar
I think they stay on until you open the door.
Old Mar 13, 2015 | 09:02 PM
DennisMik's Avatar
My lights go off when I turn the engine off. The key can still be in the ignition switch.
This may be another symptom of the wrong ECU. The body control module, SECU, is different in the 2000 & 2001 than what is in the 2002 & 2003.
Old Mar 13, 2015 | 09:24 PM
nestorlugo's Avatar
Yea true....sorry i have the fog light mod so i ride with the quarters and fogs on all the time....
Old Mar 14, 2015 | 07:51 AM
Cx1's Avatar
Cx1
I read that it could be a relay ?
Old Mar 14, 2015 | 08:18 AM
DennisMik's Avatar
Wait until you get the correct ECU in the car and see what happens. Having 2 mis-matched computers (the ECU and the SECU) trying to communicate with each other can cause unpredictable things.
Old Mar 14, 2015 | 11:20 AM
CMax03's Avatar
I'm confused ! A 2000 with a VQ35? And it''s the origina motor? Not possible!
Old Mar 14, 2015 | 11:39 AM
Yeah, we already established that.
OP, you really need to follow our simple advise rather than making things more complicated
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
