whats this picture of?
Old Apr 2, 2015 | 06:07 AM
ryanmc's Avatar
I just picked up an 03 and I was trying to diagnose an oil leak witch im thinking is the oil cooler oring but while I was looking around I noticed something that looks like an oil seal pushed in behind crank pulley but it looks bigger then the crankshaft so im not sure its that. im going to remove the pulley but im wondering if anyone can tell by this pic. you can kind of see how whatever it is sinks in just above arrow tip
Old Apr 2, 2015 | 07:38 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Yes....every car has a front crank seal.
Old Apr 2, 2015 | 07:39 AM
NmexMAX's Avatar
dot dot dot ...
Crankshaft oil/Front main seal would be my best guess.
Old Apr 2, 2015 | 07:54 AM
ryanmc's Avatar
yes what? I didn't ask if all cars have front main seals do you know what the pictures of?
it in the area of the main seal but it doesn't look like a main seal, it look like a big oring
as I look at diagrams and pictures im wondering if its the upper oil pan lip seal im seein, if no one knows I guess il know once I remove the pulley
Old Apr 2, 2015 | 10:07 AM
Striker2237's Avatar
That is most likely the front main seal, the front main is sometimes bigger than the crank because some have a metal ring wrapped in the seal that you have to use a tool to press onto the end of the crank.
Old Apr 2, 2015 | 10:08 AM
NmexMAX's Avatar
dot dot dot ...
Hmm
Old Apr 2, 2015 | 10:55 AM
ryanmc's Avatar
I found another pic in the what have you done today thread this came from user named donkeypunch it shows it more clearly and now im thinking its normal?
Old Apr 3, 2015 | 03:16 PM
FanaticMadMax's Avatar
Yes that is normal, my crankshaft looks like that, seem like part of it is the RTV for the upper oil pan gasket since there's no actual gasket for it, only the pan has the gasket, it sucks but true.
bigfrank
Oct 1, 2015 12:51 PM
MichMaxFan
Sep 30, 2015 09:18 AM
