Help! Hit 2K RPM and stalls!!
Old Apr 24, 2015 | 06:04 PM
mbs xk8's Avatar
Hello all. I have a 2000 Maxima with 200k miles.
I'm bringing her back to life after sitting for a few months. I've replaced the battery, fuel pump, fuel filter, MAF sensor, and alternator... but I can't get past this problem.
When driving and accelerating, and I hit 2,000 rpm... the car wants to stall and die. I can't get her to rev past 2,000 rpm when in Drive. BUT... when I'm in Park and idling, I can rev all the way up to the redline.
Any ideas? I've read some posts, but can't find a solution.
Thanks for any help you can provide!!
Old Apr 24, 2015 | 07:45 PM
DennisMik's Avatar
I'm assuming you have no check engine light, so I would say the MAF is bad.
Old Apr 24, 2015 | 10:34 PM
mbs xk8's Avatar
No check engine light and I've already replaced the MAF with a new one.
Old Apr 25, 2015 | 08:19 AM
cornholio's Avatar
replaced with oem maf? or junk from autozone?
Old Apr 25, 2015 | 09:46 AM
mbs xk8's Avatar
MAF replaced with one from Courtesy Nissan web site from Dallas
Old Apr 25, 2015 | 09:48 AM
cornholio's Avatar
i hear those ones are good
maybe check wiring to maf for power/continuity?
Old Apr 25, 2015 | 12:26 PM
maxiiiboy's Avatar
Does it look like you are in Limp Mode? If so, your other suspects are the ECTS (Engine Coolant Temp. Sensor), the TPS (Throttle PS), and the CPS (Crankshat PS). Try to replace the ECTS - it's not expensive.
Old Apr 26, 2015 | 09:37 AM
mbs xk8's Avatar
Don't think I'm in the limp home mode because the engine will rev to its redline if I put the transmission into park.
Its only when I'm in drive that it cuts out and stalls when I get to 2000 rpm.
ECU issue?
Need help
23
Oct 2, 2015 08:56 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
