01 maxima pulling to the right
Old May 3, 2015 | 02:40 PM
Trin1j23's Avatar
My 01 maxima keeps pulling to the right. It happens at slow and fast speeds. I recently had both my control arms done and an alignment.
Old May 3, 2015 | 05:40 PM
Cotozic's Avatar
It could be torque steer, which is only extremely obvious when you accelerate hard. It's usually just a light pull to the right.
Old May 4, 2015 | 10:42 AM
KyleWI's Avatar
If it's only pulling one direction, it sounds like an alignment issue to me.
If it happens at a consistent speed, I'd say it's the alignment wasn't done correctly. Say 40-60 MPH cruise control type speed.
If this only started happening after they did the control arms, it is more than likely their causing.
Here's things you could check though:
-Tire Pressure
-Mismatching tires
-A sticking brake caliper
Old May 4, 2015 | 03:29 PM
tnj9's Avatar
-Tire Pressure
-Mismatching tires
+1 , check tire pressure and make sure all tires are the same, rotate them, see if problem still occurs
Old May 4, 2015 | 03:33 PM
Donkeypunch's Avatar
First match air pressure and then rotate the tires.
There's a good chance it's just the tires.
acw
Aug 13, 2015 12:50 AM
cmpowell86
Aug 10, 2015 12:35 AM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
