NEED HELP! 2002 Nissan maxima
I purchased my 2002 Nissan maxima a year ago in March the bearing rod throw so I got a new engine put in this year once I got it back I notice my check engine light was on so I checked the codes P0444,P0301,P0430,P0011 all the codes showing so I started changing thing NGK spark plugs with the boots where first then I changed the crankshaft position sensor after that the purge control system control was also change none of this helped when I drive it with more then half a tank it drives ok and then when it get to half and below it will have a rough idle, cut off, jurking when pulling off, and RPM jumps when jurking from 1000 to 4000 please help I had the cutting off problem in my 99 maxima it was the vacuum bypass relay wasn't all the way plugged in please help these shops are not
xUNIxPanther
08-27-2015 10:09 PM
District
08-15-2015 08:23 PM
