Weird OBX outlet size for cat inlet
Again, just affixing a 3" catback does not mean more power, as a matter of fact, it rarely does...why not? I am really losing faith in some of you. Do you guys really believe that a bigger exhaust behind a smaller exhaust flows more? Explain........hint......it could......why? FWIW.....I been doing this......engine building/tuning/dynoing.....since before these maximas were new....
I don't care how long you've been doing whatever you believe. Doesn't mean you're right. Again, it's not like this info is new.
Can't believe I missed this post. Exellent read for some of you fellas. This gentleman seems to know what I am hinting too.
More spoon feeding I suppose..
https://maxima.org/forums/dyno-discu...ml#post6241702
Why don't you read through the thread?
WOW!!!!!!! Those numbers are phenomenal!!! I am definitely sold on the 3.0" catback!!! Now it's time to order! Sadly Cattmans not making them anymore, so I guess I'll settle on BRM.....
Just ordered the 3 inch BRM catback and magnaflow 12641 (30x6) resonator today! I'll let you guys know when I install my intake, headers, cat, and catback and I'll post some sound clips too!
Well..... Had my intake manifold, cooling fans, heat shields, and crossmember/mounts off and then I started trying to unbolt the y pipe from the cat and it wouldn't budge. My Dad and I were trying to get it off for about an hour, I used lots of penetrating fluid and even used a torch. So, now I'm putting everything back together and will just be having a shop do it.....
It was the y pipe to main cat bolts. However, I just realized that since I'm redoing my entire exhaust from the block back, I could've just cut everything out. But, since I got my own resonator to use for the catback, I am having my friend weld it in, and since he's got to take measurements and what not, I just figured I would have him do it all. I wanted to help with the install, but his uncle wouldn't let me due to liability issues in the shop. I do have a question though. The high flow cat I got has a 3 inch inlet and outlet, but for the y pipe to inlet, I bought a 2.5 inch gasket. The y pipe is 2.5 inches, so should I go with the 2.5 inch gasket or a 3 inch gasket?
Finally got everything installed! Had a friend install the 3 inch high flow cat and 3 inch BRM catback with an 18x6 magnaflow resonator and then I installed the headers over the last couple days. I took it for a test drive this morning and it is so much faster!!! It's pretty darn loud, but it's whatever. I'm just glad to have the precats gone and the extra power. I'll post some sound clips once I get a chance.
I think some of the drone/vibration noise is coming from the piping between the cat and the resonator. It's resting on one of the supports, so maybe I'll see if I can get it lifted off the support somehow.
I think that's what it is. There's two of them. One before the resonator and one after it. Couldn't I just remove the safety catch, or is it necessary to have?
knight_yyz
Nov 1, 2015 01:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
's
