Brakes go to floor at over 90 mph or high rpm
Old Jun 11, 2015 | 05:14 PM
cdoublejj's Avatar
at high speed or RPM for extended periods of time my brake go to the floor. the car stops and they work but if this is a boosted brake car it's like the boost is gone and brake goes in a LOT further than it normally does. thoughts? they pump right back up when i let out of it and or coast for a bit.
Old Jun 11, 2015 | 05:27 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You're losing vacuum. Less is created at high rpm.
Sounds like booster replacement time.
Old Jun 12, 2015 | 12:34 PM
FanaticMadMax's Avatar
definitely the brake booster, the diaphragm is busted.
Old Jun 14, 2015 | 11:02 PM
cdoublejj's Avatar
i think it's leaking more than busted since it doesn't do it all the time 100% consistent but, i'm sure after 13 years the rubber in booster or the diaphragm or hose has crack. are there any hoses going to the diaphragm?
Old Jun 15, 2015 | 03:40 AM
rebelhell's Avatar
BRAKE BOOSTER OPERATING CHECK
1. Stop engine and depress brake pedal several times. Check
that pedal stroke does not change.
2. Depress brake pedal, then start engine. If pedal goes down
slightly, operation is normal.
BRAKE BOOSTER AIRTIGHT CHECK
1. Start engine, and stop it after one or two minutes. Depress
brake pedal several times slowly. The pedal should go further
down the first time, and then it should gradually rise thereafter.
2. Depress brake pedal while engine is running, and stop engine
with pedal depressed. The pedal stroke should not change
after holding pedal down for 30 seconds.
Old Jun 15, 2015 | 07:28 AM
ac max 92's Avatar
Possibly brake booster or vacume like previously stated but if you've had your brakes done recently you may also want to try bleeding the lines and checking for any small leaks.
Old Jun 15, 2015 | 08:33 AM
CMax03's Avatar
Then it wouldn't be assisted if the vacuum was leaking the brakes would be hard.....I think it's your MC! Make sure your have no leaks...in the system period! Fluid disappearing? If not I bet my nuts on the Master Cylinder (MC)...
Old Jun 15, 2015 | 11:08 AM
ac max 92's Avatar
CMax, You hope George doesn't see this or he might go to collect on that lol.
Old Jun 15, 2015 | 02:50 PM
Bad *** Newb
I agree, but why only when at higher rpm?
Maybe both are bad.
Old Jun 15, 2015 | 10:07 PM
cdoublejj's Avatar
yeah i'll do that check. i can't remember any one single time it's happening during normal city driving. you like 15-45mph driving. also the snap-on verus is reading a REAR wheel sensor that is saying something like 150-250 mph. not sure if a sensor or the verus.
mvm062
Nov 30, 2020 09:00 AM
bryants95max
Oct 2, 2015 12:52 PM
slowlifer
Sep 8, 2015 05:53 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
