Rebuilt pressure PS hose make noise??
Old Jun 12, 2015 | 12:14 PM
tool46&2's Avatar
Anyone who has had their OEM pressure power steering hose rebuilt, does it make the noise (moan/groan) that some of the aftermarket hoses produce?
The pressure hose on my 2002 maxima is leaking. I would rather not pay $200+ from Nissan for a replacement OEM hose and I'm not interested in a aftermarket hose that makes noise (Been through that on my old 94 maxima).
Old Jun 12, 2015 | 12:31 PM
FanaticMadMax's Avatar
you can not rebuild pressure hose, it's rubber, it like saying I want to buy a rebuilt tires, only route is just buy a new hose or go to a salvage yard and get a used one.
Old Jun 12, 2015 | 01:05 PM
rebelhell's Avatar
They are not so much rebuilt per se, however a hydraulic hose company can usually make you a knew hose using the original fittings. From what I've heard nobody has had any issues from doing so. I'd even wager you'd end up with a higher quality hose that way.
tool46&2's Avatar
I've read otherwise in this thread:
https://maxima.org/forums/5th-genera...sure-hose.html
this thread:
this thread:
https://maxima.org/forums/5th-genera...hose-pics.html
with pictures of a repair here:
http://s922.photobucket.com/user/Joh...?sort=3&page=1
Old Jun 12, 2015 | 05:36 PM
Child_uv_KoRn's Avatar
Bad *** Newb
As I posted in another thread I've had no issue with my Gates. Some said theirs whined, though.
I would try the Gates (or w/e brand), but buy it from Amazon. If it whines, then send it back haha. It's pretty damn easy to swap in a hose. Just don't remove the old one unless you're satisfied with it.
Old Jun 12, 2015 | 06:49 PM
cornholio's Avatar
same experience with my edelmann. no noise whatsoever.
i'd think the "rebuilt" one would be fine as long as the same size hose is used.
bleed it proper and i don't see why you'd have any issues
Old Jun 12, 2015 | 07:07 PM
Bad *** Newb
On an interesting note, I replaced a hose in an acura TL. Install was a pita (thanks honda jerk offs, so retarded), and it started whining days later just a little when turning.
It whined for weeks, but we weren't about to replace it, again (OEM is 200 also). Then one day it ran low on fluid! I was about ready to tear Gates a new *******. Turns out that the thing burped a giant amount of air and almost emptied the resevoir!
I don't think that could happen with ours, but it's pretty damn intriguing LOL
Old Jun 12, 2015 | 08:00 PM
george__'s Avatar
use oem
aftermarket is a POS
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Professor
Aug 21, 2015 07:36 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
