Trans seal leak 5th gen maxima
Old Jun 14, 2015 | 04:52 PM
carlosvq30's Avatar
I tried searching but couldnt find much
Quick question to those that know
My car is leaking trans fluid thru axle seal
Its been leaking for a while
Now sometimes randomly will grind before going into 3rd or 4th gear. Not all the time just sometimes unless i wait like 4-5 seconds before shifting. So my question is ,is it because low trans fluid ? And 2nd. Is it safe to change/add gear oil to trans no matter how many miles i know in autos its tricky but how about manuals is it okay to add new gear oil ?
Thank you all (:
Old Jun 14, 2015 | 05:19 PM
Fakie J Farkerton's Avatar
New gear oil is always ok as long as you use GL4.
Not sure about your grinding issue..could be the syncros, but IDK.
The axle seal is pretty straight forward.
Just don't tap it in too far.
Old Jun 14, 2015 | 05:22 PM
carlosvq30's Avatar
Originally Posted by Fakie J Farkerton
New gear oil is always ok as long as you use GL4. Not sure about your grinding issue..could be the syncros, but IDK. The axle seal is pretty straight forward. Just don't tap it in too far.
Yeah. I might as well replace the axle
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
morteljc
Oct 19, 2015 10:47 AM
Finkle
Sep 27, 2015 09:53 PM
