Loud squeal, one of my pulleys?
Old Aug 9, 2015 | 08:16 AM
02PearlSE's Avatar
Hey y'all, the other day I started up my max and had a loud squeal, what I originally though may be a power steering issue, but it is relieved within a minute of starting/driving. After sitting for a while I notice it happens when I start it, if I rev around 2-3k when cold. I'm starting to figure it might be a pulley? It's so tight down there though (I'm used to a 4.6 v8 where it's wide open) that it's hard to tell.
Anyone else have/fix this issue in the past?
Old Aug 9, 2015 | 09:49 AM
VQ35maxima=Beast's Avatar
It is most likely your idler pulley, try to tighten it and see if it still does it, if not it is most likely bad. Try to spray some wd on the pulley to see if it squeels at all.
Old Aug 9, 2015 | 11:14 AM
maxipower's Avatar
loose belt
Old Aug 9, 2015 | 12:18 PM
DennisMik's Avatar
Some of those alternator bearings can get pretty loud, too.
Old Oct 6, 2015 | 11:58 AM
Callmefrosty's Avatar
Yes I am having a similar problem at the moment. Its either a quick squeal noise at start up or if im driving and put the A/c on it will start squealing endlessly till i turn a/c (Squeal starts during acceleration sometimes). What could this be?
Old Oct 6, 2015 | 03:12 PM
mclasser's Avatar
Sounds like the AC/Alt belt. Depending how old it is, you can try tightening it a little first to see if it helps before replacement.
Old Oct 6, 2015 | 03:15 PM
5thgendriver's Avatar
see post 2 above....
Old Oct 6, 2015 | 03:20 PM
foodmanry's Avatar
Da Roller Coaster!
AC clutch or compressor bearings.
Old Oct 7, 2015 | 02:12 AM
Turbonut's Avatar
Those serpentine belts need to be pretty tight and any looseness will result in
a squeal on startup or when additional stress is placed on the belt, e.g.the A/C
is engaged. Push on the belt to see if any deflection, then tighten the belt by
turning the tensioner pulley adjusting rod AFTER loosening the bolt on the pulley.
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
