2002 Center Console Question
Old Jan 27, 2002 | 12:22 AM
2002 Max SE's Avatar
Thanks everybody for all of the good advice. I have been watching the board for the past couple of months and ended up buying a 2002 SE in super black about a week ago. My car had been on the lot for a couple of weeks, and has every option including navi. I wasn't planning on buying a loaded version and I was planning on waiting for HLSD, however I took advantage of the opportunity to get the car for $800 below invoice (after rebate). Quick question - I noticed on the Nissan website the 2003 Maxima console is described as follows:
"Push a button to raise or lower the armrest between the front seats. Just select the height that's right for you. Inside, there's dual-level storage, including a cell phone compartment with a 12-volt outlet for charging."
I don't think my center console has a cell phone compartment, only a pull out cup holder behind the console with an outlet above it. Does anyone have a different console?
Old Jan 27, 2002 | 01:42 AM
2001SE's Avatar
pull the armrest itself, don't press any bottons, just pull it, you'll need an amount of force to open up this "secret" place, where you put your cellphone and pull the cord outside of that "secret" place to the 12-Volt Outlet.
this is confusing, but all you have to do is pull the armrest itself kinda from the top and not push or press any other bottons, just bascily pull it
Old Jan 27, 2002 | 01:58 AM
JKiMaxAC's Avatar
Old Jan 27, 2002 | 02:43 PM
thanks 2001SE
2001SE,
"this is confusing, but all you have to do is pull the armrest itself kinda from the top and not push or press any other bottons, just bascily pull it"
Thancs for the avise champ - I'll get ahuld of you when my spilling lessins begen
Old Jan 27, 2002 | 04:32 PM
NissanisGood's Avatar
The Nissan Website
Nissandriven.com also shows that a 6-disc in-dash changer is standard on all models, Bose or not. It is in the "Audio Spec" section. Is this inside that secret compartment?
Old Jan 27, 2002 | 06:36 PM
Ludacris's Avatar
Re: The Nissan Website
No...it's inside the dash where the CD slot on the radio is..
Old Jan 31, 2002 | 10:15 PM
xydavid's Avatar
Originally posted by JKiMaxAC
You know when I first got my 2k, I saw the reference to it and couldn't find it for anything -- even read the owner's manual cover to cover. I finally called 1-800-NISSAN1, even the customer service reps had NO clue where it was -- his only explanation was it might have been a misprint (he had even asked around). Then one of my friends found it one day by accident!
Old Jan 31, 2002 | 10:17 PM
xydavid's Avatar
If you have the Navigation system, however, you have a single CD in-dash (replaces the Nav CD located behind the Navigation screen). If your car is equipped with Nav, however, the changer is trunk-mounted.
Old Feb 1, 2002 | 05:57 AM
ru4real's Avatar
It's almost as hard as finding that secret spot on a woman.
Old Feb 1, 2002 | 01:15 PM
aadro's Avatar
Re: thanks 2001SE
Originally posted by 2002 Max SE
2001SE,
Dumb question: Is this true of the 2k2 Maxima as well? I pulled and pulled and pulled ... and NADA!
Old Feb 1, 2002 | 01:28 PM
JBWhitley's Avatar
Re: 2002 Center Console Question
Are you saying that there is a 12v outlet inside the armrest. Mine has one on back, but it is a 2k. It also has the adjustable armrest, shallow tray and deep tray.
Old Feb 1, 2002 | 03:38 PM
MichaelAE's Avatar
Re: Re: 2002 Center Console Question
Right, and if you look really carefully you'll see a small cut out on the back of that tray which would allow for you to run the charger cable out to that rear charger outlet.
Old Feb 2, 2002 | 09:09 AM
aadro's Avatar
Re: Re: Re: 2002 Center Console Question
Okay! Found it. I think. It's just a shallow tray, but it does have a cutout towards the driver's seat that would allow a cord to pass through. Man! When I finally found it, it felt like I had broken something, 'cuz there's no latch or anything to release it, and it pops out exactly like you broke it!
Old Feb 2, 2002 | 09:41 AM
Maxme's Avatar
I just noticing this morning that the top adjustable section of the armrest seemed to be thicker than it should be , so there's some kind of hidden storage there?
Old Feb 2, 2002 | 10:43 AM
MichaelAE's Avatar
Re: Re: Re: Re: 2002 Center Console Question
Yeah, you sort of get used to that. I think it is inevitable that we will all be replacing that little latch within a couple years. It can't last that long.
Old Feb 2, 2002 | 11:03 AM
Maxme's Avatar
ok, I found it , I was wondering if I was going to have to use one of those ugly split tail adapters to plug in my phone and my radar dectector, because i damn sure need to get my radar dec. hooked up in this damn speeding ticket magnet!
Old Nov 19, 2007 | 03:26 PM
bigjoe87865's Avatar
ahhh.... i found it... a bit shallow though...my brick MDA wont fit with the belt holster
Old Nov 19, 2007 | 03:55 PM
sublunary's Avatar
i see you forgot that you were looking at an old thread in all the excitement of finding the "secret"
Old Nov 19, 2007 | 07:08 PM
SoonerFan's Avatar
Cletus
great...you bumped a 5 year old thread to give us the wonderful news that you figured this out.
the first time i sat in a 5th gen...before i even test drove it...i figured this out. not really that crazy and exciting.
Old Nov 19, 2007 | 09:31 PM
s2kver02's Avatar
^^^ hahaha same here....
Old Nov 19, 2007 | 09:54 PM
Scottwax's Avatar
That's Mr. Detail to you
I knew that from detailing a couple, even before I bought mine.
Old Nov 20, 2007 | 04:53 AM
if someone posts in here "hey....i just found it too!.... great thread... wanna make phrandship?" then my bump was worthwhile!
jk..
i shoulda read the date.. my bad.
Old Nov 20, 2007 | 07:06 AM
BMWHIGH1's Avatar
I think it worth it i didnt know this
Old Nov 20, 2007 | 07:39 AM
Maxme's Avatar
Hey does anyone have a good source for OEM parts , my arm rest needs replacing.
Old Nov 20, 2007 | 07:43 AM
jreddington3's Avatar
Yep,
It's easy to rag on someone that resurrects an old thread. However, in many cases this shows that the poster did what we all should do, search before posting and creating a redundant thread. Post a new thread and then you get whacked the other way with responses that say you should have searched and found such and such a thread.
I've been using this "secret" comparment for years, primarily to hold my log for gas and maintenance records. It's about the perfect size for it. But I had never noticed the cutout allowing a power cord to run to the outlet in front of the back seats. So I learned something too. Sounds like this is the exact kind of serendipity that forums are designed to promote.
Old Nov 20, 2007 | 07:50 AM
SoonerFan's Avatar
Cletus
Sticky: Parts List & Web Sites for 5th gen Parts
Old Nov 20, 2007 | 07:55 AM
SoonerFan's Avatar
Cletus
Originally Posted by jreddington3
Yep,
you search for old threads to find the answer to your question so you dont have to start a new thread.
you dont dig up an old thread with a post that doesnt
a. help answer the question
b. ask something that hasnt been answered in the thread
Old Nov 20, 2007 | 08:39 AM
Maxme's Avatar
Most of that info was posted in 01' , wasn't sure it was still fresh
"boomer sooner" grew up in norman
Old Nov 20, 2007 | 11:59 PM
jasonmax's Avatar
Yep,
have you noticed that there are actually 2 cup holders in the cup holder at front, which can be taken out for different size.
Old Nov 21, 2007 | 06:03 AM
did you know the front coin tray under the climate control can be taken out as well?
Old Nov 21, 2007 | 06:13 AM
KRRZ350's Avatar
Old Nov 21, 2007 | 06:21 AM
SoonerFan's Avatar
Cletus
and you can stick other stuff in it
Old Nov 21, 2007 | 11:00 AM
jvl856's Avatar
im lovin that black leather interior.
Old Nov 21, 2007 | 06:53 PM
Check out http://nissanpartsonline.net/
Actually the parts department of Jerry Rome Nissan in Springfield, MA. They used to have a link from the "official" dealership web site. However, I suspect Nissan may try to keep them from specifically associating with selling parts under manufacturer's list.
If you can't find the exact part through the site, send them an email with what you're looking for. They've looked up parts for me and have been very quick in shipment. Of course, I'm located less than 50 miles away. Even asked about picking up the parts myself, but again, I think they have to keep themselves separated from the dealership so all business through the web site is by shipping.
Old Nov 21, 2007 | 07:02 PM
ooo ... what is that?..
and what is that cut out you have on the lower right hand side of the shifter?... i think i have it too... not sure for what feature its for ....
Mar 12, 2020 12:06 AM
GregL65
Sep 7, 2015 10:33 PM
boomerbrian
Sep 4, 2015 08:25 AM
Justin Kroll
Sep 2, 2015 11:06 AM
