Wifey bought a new stereo for her car. It's a pioneer fh-x720bt double din. The guy at Bestbuy said we needed this line output converter for the stock amp to work with the new head unit .It's a PAC LOC PRO LP6-4...but I'm confused as to how to wire it up and the crazy thing is I looked up this model LOC online and there's no info about it whatsoever...not even on PAC's website...there's an LP5-4 model and LP7-4 model but no LP6-4
First of all, you only need it if you are replacing a Bose radio.
The PAC LOC PRO must be a newer line of adapters. Take it back and get the older NIS-2 adapter, it works fine. The NIS-2 comes with the wire harness adapters. You just need the antenna adapter and trim plate.
Here is a photo of it in my car.
yeah I'm replacing the factory bose headunit with a pioneer...I contacted PAC n they told me best buy has to have their own product number so the LP6-4 at best buy is actually the LP7-4.
the best buy guy might have shafted you. a LOC turns a high level signal into a low level signal, which your cd player already has. I am not sure whether or not this particular LOC can switch it from low level to a high level, if it can then you are set. What does the back of the stock bose head unit look like?
based on the drawings of this unit, this is the unit you need.Originally Posted by DennisMik
First of all, you only need it if you are replacing a Bose radio.The PAC LOC PRO must be a newer line of adapters. Take it back and get the older NIS-2 adapter, it works fine. The NIS-2 comes with the wire harness adapters. You just need the antenna adapter and trim plate.
I don't know how the back of the bose looks but I went ahead and bought the NIS-2 Adapter...should be here by Monday
I think hrtbrk1 meant the back of the Pioneer radio. The Bose radio is out and not part of the equation.
Anyway, here is the wire connections for the Pioneer harness to the PAC ROEM harness (the A cable without ends).
There is one wire from the Pioneer that you need to connect to 2 wires on the PAC ROEM cable. Pioneer calls it the power antenna wire. It needs to go to the PAC ROEM power antenna wire and also the amplifier on wire.
Code:
Wiring a Pioneer FH-X720BT to the PAC ROEM NIS-2 A-cable PIONEER NIS-2 FUNCTION COLOR COLOR - - - - - - - - - - - - - - - - - - - - - - chassis ground black black 12 volts constant yellow yellow 12 volts switched red red dashlights orange/white orange LF speaker + white white LF speaker - white/blk white/blk RF speaker + gray gray RF speaker - gray/blk gray/blk LR speaker + green green LR speaker - green/blk green/blk RR speaker + violet violet RR speaker - violet/blk violet/blk power antenna blue/white blue/white blue (connect to blue/white wire) WIRES NOT USED radio mute yellow/black on Pioneer cable LF speaker low white/red on PAC ROEM NIS-2 cable RF speaker low gray/red on PAC ROEM NIS-2 cable LR speaker low green/red on PAC ROEM NIS-2 cable RR speaker low violet/red on PAC ROEM NIS-2 cable
lol i was trying to figure out the thought process of why the best buy guy sold him the other module. post some pics of your install once you get started OP Originally Posted by DennisMik
I think hrtbrk1 meant the back of the Pioneer radio. The Bose radio is out and not part of the equation.Anyway, here is the wire connections for the Pioneer harness to the PAC ROEM harness (the A cable without ends).
Code:
The Adapter showed up in the mail on Saturday. Got the wires all connected to the pioneer harness just like Dennis posted. Didn't get a chance to install the stereo yet since my wife is always cruising the damn car. Hoping to get it done tomorrow after work n ill try n take some pics. The guy at best buy seemed really convincing....he was like you definitely need this or your radio wouldn't work. I showed it to my wife's cousin yesterday and he laughed at me lol...told me that is only for when u have an aftermarket amp which I don't have
Quote:
I now know of another person that I won't let touch my car.Originally Posted by ivorton23
