Help with the part in the picture and its impact
Old Oct 7, 2015 | 12:19 PM
dbacks's Avatar
I would appreciate if anyone can point to what the part in picture is called, and how its effecting the overall car performance.
File Type: pdf
Old Oct 7, 2015 | 06:19 PM
Turbonut's Avatar
Gonna guess it's the air box connection. There should be a collar that slides
over the front section so outside air is drawn in, rather then hot air from the
engine compartment.
Old Oct 7, 2015 | 08:19 PM
ajahearn's Avatar
I agree it looks like the air box connection. I would think it is not really going to hurt you because the ducting in the front of the car is just directing air in that direction. I would just try and put it back together the air intake part on the bottom of the left side is only held on by a pair of screws. That should make it visible as to what is open after it.
Old Oct 8, 2015 | 11:21 AM
foodmanry's Avatar
Da Roller Coaster!
In the picture on the left, yes those should be connection. I had the same issue on my maxima and used a silicone coupler with clamps to keep it connected tight.
On the picture on the right that is part of the intake. You are missing a downtube connector to that white airbox. It really isn't a necessary part of the car as it is just more or less a sound dampener (I think). I actually blocked mine off and removed the white box on the bottom. It is kind of a pain in the butt to remove. Either way it doesn't affect your performance. You may want to find a cap for the open port on the bottom of your "air ram" box where that connection oririginally connected. I capped mine...I used some sort of silicone end cap with a clamp.
Old Oct 17, 2015 | 01:45 AM
cdoublejj's Avatar
i used a torn up shirt and duct tape to a make a "seal" so they fit tighter. last i checked it's doing it's job. if any thing it's more air flow but, water and crap aren't so good for it so opted to "shim" the connection/coupling.
Old Oct 17, 2015 | 07:58 AM
george__'s Avatar
that is not malware?
Old Oct 20, 2015 | 12:05 AM
cdoublejj's Avatar
malware? as in computer viruses? Did your auto correct or spell check change a word?
italianbonez718
69
Mar 9, 2016 05:13 AM
doctorpullit
Detailing
19
Feb 7, 2016 03:15 PM
ef9
Oct 6, 2015 04:42 AM
Vaughan
Oct 5, 2015 06:27 AM
bigfrank
Oct 1, 2015 12:51 PM
