No spark and no spray on fuel injectors
Hello I'm new here and I ran into a problem I replaced my motor on my 02 max 6 speed everything all good when I turn it on. It ran for 10-15 min and then it shut off now it won't turn back on I check all the fuse, wiring harness, the sensors,fuel pump it has a new starter. Fuel injecting not spraying and no spark on the coils. I spray some start fluid in it and it cranks and It will start until I stop spraying.I don't know if this makes a difference but my friend had his computer on the car while it was running and I think he tried to clear the codes while it was on
You evidently do have spark because the engine starts with starting fluid.
No fuel could be that the NATS has immobilized the car. Look at the red security led in with the clock. If it is on or blinking when you have the key in the ignition switch, the car is immobilized.
conansriver
Sep 3, 2015 06:38 AM
homewrecker
Aug 24, 2015 08:56 PM
Viralkill
Aug 17, 2015 10:54 AM
