VQ30 Engine Pull
Old Nov 12, 2015 | 05:34 AM
Lowered_a33's Avatar
VQ30 Engine Pull
Im Pulling the engine out of a Maxima and i am going to start to build it. just curious to see if theres any obstacles that i might encounter when doing this. any advise/ tips? Thanks Very Much hope to hear soon as i want to get this engine and tranny out ASAP. thanks!
Old Nov 12, 2015 | 03:15 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Not really. It's very straight forward. I did it by myself the 1st time without any issues.
Soak the carrier bearing and bolts (pass. CV) before attempting to remove them. They are usually oxidized in there hardcore. I've had to use punches and beat it out of the bearing before.
Do the same with the exhaust.
An impact wrench is invaluable for the large nuts/bolts.
I lift the engine at an angle and slip off the tranny, then pull it out from underneath. To install the tranny I have lifted it by a starter bolt or used a tranny jack (I love tranny jacks).
I never saw enough clearance to ever pull the motor and tranny through the top.
Two people make it easier, but I have done the 5.7 swap completely by myself and the only extra time added was dropping the motor in...without a leveler LOL
Old Nov 13, 2015 | 06:12 AM
Perfect, Thanks! now just to clarify, do i have to remove the tranny from the bottom and pull the motor out from the top or can i just pull both the engine and tranny together.
And also, did you remove the ECU? if so how? and where was it located in the car. i want to say its on the passengers side but im unsure.
Old Nov 13, 2015 | 08:54 AM
cornholio's Avatar
ecu is on the floor between the driver and passenger foot well, pull the two covers off the sides and it's 4 screws to get it free. will require a small 90 deg screwdriver or hex head depending on year of car
Old Nov 13, 2015 | 08:17 PM
Bad *** Newb
Gear wrench
Apr 16, 2020 05:15 AM
Lowered_a33
Nov 13, 2015 11:51 AM
Pnjboyzz
Oct 7, 2015 10:47 PM
ballerchris510
Sep 11, 2015 05:29 PM
pktaske
Sep 4, 2015 08:40 AM
