How to replace horn?
Old Dec 2, 2015 | 07:49 PM
Andy29's Avatar
And with which one?
My horn is ultra high pitched for some reason. More than usual. It's funny but embarrassing. Is it blown out?
How do I go about replacing it and what should I buy? There's a bunch of aftermarket horns but I don't know which ones fit. Thanks
Old Dec 2, 2015 | 08:04 PM
DennisMik's Avatar
You have 2 horns. One is behind the grille on the hood latch support and the other is in with the engine by the coolant expansion tank. They are not the same pitch, one has a lower tone than the other. It seems that the lower tone horn has stopped working. Open the hood and have someone blow the horn while you check for the dead horn. It is easy enough to replace. Unplug one wire and remove one 14mm nut. Easy peasy.
You can get another Nissan horn or you can get other, louder horns. Non nissan horns may need some modification to install. I have Hella brand horns that are louder but needed some modification.
Old Dec 2, 2015 | 08:31 PM
Donkeypunch's Avatar
Go to harbor freight and get the air horn they are ultra loud.
Old Dec 3, 2015 | 06:48 AM
TallTom's Avatar
On the 02 and 03, they are next to each other by the hood latch.
Old Dec 3, 2015 | 12:22 PM
DennisMik's Avatar
It's good to know that Nissan pulled their heads out of their a$$ and put them side by side. I lost a lot of skin on my knuckles putting them side by side on my 2000.
Old Dec 3, 2015 | 12:35 PM
TallTom's Avatar
Here is an old thread that has a lot of info: https://maxima.org/forums/5th-genera...heir-horn.html
Maxron
May 10, 2021 01:18 PM
eddie982
23
Dec 22, 2015 06:40 AM
rhc43
Dec 3, 2015 01:42 PM
dcam0326
Nov 23, 2015 12:21 AM
maxima297
28
Nov 13, 2015 11:09 PM
