OBX headers don't look like equal length
I've never heard of unlimited life timing chains. I also don't know how well my car was serviced before my owner ship. i can only assume there is an inspection port to check the stretch with some sort of spec to compare to for measurement/gauge wear. Who knows about all aluminum rads on 5th gens? :P
As far as radiator did yours start leaking up top drivers side by nissan mold? Or something else?
Well it sounds like the best way is to find how to check if it's stretched.
I consider an all aluminum rad quality plus, i may actually go forced induction so it would be nice to have an all aluminum rad, LSD trans with shift kit and exhaust in place. struts springs wouldn't hurt either. :P
Well it sounds like the best way is to find how to check if it's stretched. I consider an all aluminum rad quality plus, i may actually go forced induction so it would be nice to have an all aluminum rad, LSD trans with shift kit and exhaust in place. struts springs wouldn't hurt either. :P
non LSD trans just cut fuel, supposedly LSD supposed to put some power to the other wheel which sounds like a win win cause i think i definitely spin them in corner and when taking off, especially with TC turned off. THAT IS ALL I KNOW!
don't think i've driven any OTHER front wheel drive car with power let alone one with LSD.
If you go forced induction transgo, exhaust and a decent suspension setup are must have imho. Lsd isn't what you think it's going to be on the auto. It's not the same as the hlsd on the manual. I have it on my Turbo'd Max and I almost always turn it off. I should probably use it more but In the back of my mind I have a feeling like it'll burn up my auto quicker if I use it. Not saying that's a fact just saying that's the feeling I get.
That's what I'm saying it's not like the manual hlsd. It's traction control button tcs. It works with abs and something else. I'm not really sure the ins and outs of it. I figured all autos came with it but evidently not.
Thats not an LSD, thats traction control. LSD do not use the brakes or cut throttle, if its an auto or a manual it does not matter LSD do not use the brakes or cut the throttle. An lsd in the case of most gear or clutch driven lsds if one wheels spins X amount of times then the other wheel has to spin Z amount of times. It could be ration of 2:1 or maybe 1.5:1 it gets complicated. VLSDs are driven by fluid so they are completely different.Traction control is a total different system, it uses the brakes and the throttle to limit loose of traction. When it detect slip it first uses the brake and if that is not enough it cuts power. But you can still have an open diff with traction control in fact most cars do.
Thats not an LSD, thats traction control. LSD do not use the brakes or cut throttle, if its an auto or a manual it does not matter LSD do not use the brakes or cut the throttle. An lsd in the case of most gear or clutch driven lsds if one wheels spins X amount of times then the other wheel has to spin Z amount of times. It could be ration of 2:1 or maybe 1.5:1 it gets complicated. VLSDs are driven by fluid so they are completely different. Traction control is a total different system, it uses the brakes and the throttle to limit loose of traction. When it detect slip it first uses the brake and if that is not enough it cuts power. But you can still have an open diff with traction control in fact most cars do.
LSD is an internal mechanic part inside the trans, it helps deliver more power to the pavement and in doing so SHOULD reduce the need for TCS to kick in and thusly go a little bit faster.
I've never driven my year maxima without it. So it's hard to say for me how well it works. I can say that I don't get the horrible torque steer that I read about. I have a little not bad at all though.
i get torq steer and for some reason i seem to think my car lacks LSD, i think i decoded the VIN once. All I know is people do LSD tranny swaps but, also if adding more power, one probably wants LSD to help put it to the ground. might also help tire life.
I get it just not as bad as people say they have it without it. You can find out for sure if you have LSD or not when you change your cv shaft. If you can see through it you don't but if you see a bar in between the shafts you do.
interesting, didn't know that. i doubt i'm gonna dig that deep, i thinking running the VIN again should work and if not good reason to get a low mileage unit and install a transgo kit.
I have extra valve bodies for sale if you would like to have no down time and install transgo but still have stock vb. I found my replacement LSD in junkyard for 200. I just installed over long turkey day weekend. They can be found pretty cheap.
Yea you could install the kit and still be able to drive the car. No down time if you wanted to do it yourself. Let me know i have two of them for sale.
Child_uv_KoRn
Oct 2, 2024 04:43 PM
eddie982
23
Dec 22, 2015 06:40 AM
blkmax1
Dec 3, 2015 08:09 AM
11maximaSV
Oct 30, 2015 02:09 PM
