Crankshaft position sensor
Old Jan 4, 2016 | 08:29 PM
Juan M. Marroquin's Avatar
I have a 2002 maxima with a 3.5L out of a Nissan Quest. I still have the original transmission. I only swapped out the engine. My transmission has half of the hole for the crankshaft sensor to go in but the engine block doesn't have a hole for it. Should I just drill out a hole to plug the sensor in? I hate how it takes about 7 seconds for the car to start and it's also embarrassing when people stare at you when it doesn't want to start. Thanks for the help.
Old Jan 4, 2016 | 09:13 PM
Child_uv_KoRn's Avatar
Bad *** Newb
You can drill it, but the upper oil pan should have been swapped with the one from the old engine.
Old Jan 4, 2016 | 09:20 PM
I honestly don't remember doing that. I think we just bolted the tranny to the engine and then installed it. I wanna just get another engine with a 6 speed tranny but they're so expensive. They cost equivalent to what my car is worth.
Old Jan 4, 2016 | 09:26 PM
Bad *** Newb
If you want to manual swap...then you might as well buy a whole parts car. The only difference between any of the motors that matters for install is the upper oil pan.
And I hope you trashed the cats when you did the swap or you will be doing it, again.
09maxshawn11
Mar 26, 2017 07:18 AM
Mike_Max1775
Nov 10, 2015 09:06 PM
09maxshawn11
Nov 2, 2015 09:17 PM
Icykilla1
Oct 30, 2015 08:03 PM
