Stillen Y-pipe owners, need to read this!!
Old Jan 28, 2002 | 06:59 PM
2kseman's Avatar
just a heads up that can save u $252 bucks in the future...
SES light came on, disconnect battery trick didn't work..
took car in for oil change and letting them know about the SES light..
one of the wires on the 02 sensor, the one connected to the y-pipe, was cut by the the black piece of metal close to the sensor(hard to explain, but one look at where the sensor is in relation to the piece of metal, and you'll understand). Bend that piece of metal away from the sensor!!!! Evidently, that senors wire was close enough to rub against that piece of metal...
this is for the Stillen pipe, I don't know about the brands, but would hurt to check it out...i know it's kinda long, but if it could save a fellow Max owner $252, it's all gooood!
Old Jan 28, 2002 | 07:16 PM
The New CLIMAX's Avatar
Re: Stillen Y-pipe owners, need to read this!!
Do you know what the code was showing for the light?
I have the light on right now and it shows a P0420 code, there is a TSB for it but it say the y-pipe is the issue?? thanks
Old Jan 28, 2002 | 07:37 PM
2kseman's Avatar
Re: Re: Stillen Y-pipe owners, need to read this!!
don't know the code, but it shouldn't be the pipe itself that's throwing you the light. In my case, the sensor read wrong since one of the wire was cut..
if there's a tsb for your code, dealer should fix it....
good luck..
Old Jan 28, 2002 | 07:52 PM
Dario's Avatar
thanks for the info ill keep that in mind should anything ever come up
flu2000
Sep 8, 2015 02:23 PM
Maxboy23
Sep 4, 2015 06:04 PM
crazyespn
Sep 3, 2015 01:30 PM
