Bought Stinger Digital Battery Terminal, What about positive battery fuse?
Old Mar 1, 2016 | 10:41 AM
NYTooCooL's Avatar
So I'm in a hurry. I'm not the biggest electrical guy, but my car is at the top of a parking deck with no power or electricity. So last night I had to install my Stinger Digital Battery Terminal. We cut and stripped the pattery chords and put them into the stinger terminal. However, We couldnt figure out how to attach the 120amp fusable link that was on the positive battery terminal. It used to be attached via that plastic piece with a screw and bolt. The stinger battery terminal is direct attachment into the terminal. How can i incorporate that fusable link? I had to get another jump this morning, made it to class. As soon as i turned my car off, no power or electricity. I'm GUESSING it's that. Or maybe need a new battery from having too many jumps prior to doing this job.
Old Mar 1, 2016 | 01:13 PM
Derrick2k2SE's Avatar
Not having the fusible link wont cause your battery to fail.
It sounds like you have a draw or the battery is dead and not holding a charge.
If you want to keep the fuse you can use an inline fuse from a stereo shop or the auto parts store. They make large ones for big systems. Just get one for 120 amps.
Old Mar 1, 2016 | 01:55 PM
NYTooCooL's Avatar
Is this the same as the fuse that comes with the Big Three Ground Upgrade? I'm also wondering now where am I gonna connect the wire for my Sub. How can I add wires if the Stinger Digital Battery Terminal only takes 2 wires?
Old Mar 1, 2016 | 05:54 PM
I don't know about the grounding kit but there are all sorts of different inline fuse holders available. It's just a fuse. It has no effect till it pops.
For the stereo power you could just tap into one of the power lines after it leaves the stinger.
Another clean option would be to run a power line from the positive post on the starter.
Steinillac
Apr 1, 2016 11:52 AM
reallywildstuff
Mar 21, 2016 07:51 PM
tarun900
Mar 5, 2016 05:33 PM
slickblack94
Feb 29, 2016 10:33 AM
sebastian2041
Feb 26, 2016 07:46 PM
