Limp mode after motor swap. Normal?
Old Mar 8, 2016 | 06:05 AM
mrjamaica98mx's Avatar
My question is it normall for a car to still be in limp mode after a motor change and the only way to get it out of limp mode is to get the abs sensor from the donor car ?This is my situation right now car is fixed running but still at shop due to stuck in limp mode. gg
Old Mar 8, 2016 | 07:48 AM
Derrick2k2SE's Avatar
I've never heard of anything like that. ABS sensors get replaced all the time They're plug and play. I recently replaced the whole ABS computer with one from a salvage yard and it was plug and play too.
Limp mode is usually triggered when the computer thinks that something could damage the motor. If certain sensors read out of range, or don't read at all, it'll go into limp to protect itself. They probably have a sensor unplugged.
Are they sure it's actually limp mode? Unplugging the throttle body in a 3.5 will still let the car run and actually get some throttle response. Other sensors will do the same while not actually in "limp".
Have they pulled any codes?
Old Mar 8, 2016 | 09:10 AM
Child_uv_KoRn's Avatar
Bad *** Newb
I bought my sentra from a guy that couldn't get it out of limp mode after TB repair.
I reset the ECU and took it for a test drive. Problem solved lol But I didn't tell him. I did the relearns later to make sure.
Try the pedal dance.
Old Mar 8, 2016 | 12:20 PM
I just went by the shop and it seems to be the abs acurator its a big box under rhe air box or by the air box.
He stated a guy came out with a computer were they put the vin # in and scanned the car and only code was abs
Old Mar 18, 2016 | 06:40 PM
maxinout93's Avatar
can you send me a link on how to do the pedal dance? Also can u do it with the blutooth device?
Old Mar 18, 2016 | 06:49 PM
Bad *** Newb
http://www.nicoclub.com/archives/g35-how-to-reset-ecu-throttle-pedal-release-idle-air-volume-learning.html
You can do relearns, timing +-2 and idle adjustment with obd2, but no reset afaik.
Old Mar 19, 2016 | 09:48 AM
maxinout93's Avatar
thanks alot man!
Old Mar 22, 2016 | 08:54 PM
Car is off to dealership to try to get them to reprogram
Old Mar 27, 2016 | 02:46 PM
After 4 months my car is back dealer reset computer $$$$ hopefully this engine will last ...
Old Mar 27, 2016 | 03:09 PM
Mattx's Avatar
You can pedal dance and reset the car without spending money to take it to the dealer.
Old Mar 27, 2016 | 05:45 PM
Bad *** Newb
I tried lol
Old Mar 28, 2016 | 04:53 AM
Mattx's Avatar
I tried lol
Some people just refuse to listen or use the search. Why would you ever take your car to the dealer for a reset? That's just mind boggling. Ohh I didn't even read where you already told him. You even posted a link wtf??
Old Mar 30, 2016 | 08:09 AM
As stated the mechanic took it the car was not in my pos
Old Mar 30, 2016 | 08:14 AM
Bad *** Newb
I hope he ate the bill for being incompetent.
blkmax1
Mar 10, 2016 03:14 AM
carlosvq30
20
Mar 5, 2016 02:27 AM
reallywildstuff
Mar 2, 2016 02:36 PM
