2003 Maxima Engine Install car....
Old Mar 23, 2016 | 07:59 PM
Drewzown's Avatar
Hello,
Just spend 8 hours pulling a engine time to put it all back together.
I purchased a 2003 Maxima engine for the swap so maxima heart now.
I am doing an engine installation into a 3.5 2002 Altima.
This will engine up being a daily driver.
I will post pictures of the install as I am doing all the work front the top of the car, that's how I pulled the engine to begins with.
All I am wondering is should I use a 2003 maxima transmission for the swap or stick with the same Altima transmission I believe they will both work
Old Mar 24, 2016 | 06:28 AM
NmexMAX's Avatar
dot dot dot ...
Should just use the Alti transmission, less work.
I'm assuming AT?
Old Mar 24, 2016 | 01:44 PM
Drewzown's Avatar
Yes the transmission is going to be A/T.
My conclusion is I will be using the maxima transmission on th install.
Then I will install a transgo kit I the Altima transmission because you need a backup if you have an A/T.
I will be installing on Monday as this is my hobbie.
Old Mar 24, 2016 | 03:37 PM
NmexMAX's Avatar
dot dot dot ...
not in the Maxima world, it's oftentimes the other way around.
My AT has 170k/and close to 13 years of very hard miles on it and it's fine.
I'd double check the FSM wiring diagrams for both cars and closely compare. It should be fine since it's an 02 Alti, but I know 02/3 Maximas had CAN, and that can be somewhat of a PITA to deal with if going into a non CAN ECU/vehicle.
Old Mar 26, 2016 | 07:33 AM
Drewzown's Avatar
I have never heard of CAN. Googling didn't help
I have them side by side difference is the oil pan and also the dipstick.
there is an extra sensor on the Altima transmission that I will trying to swap over on the maxima transmission.
Old Mar 30, 2016 | 01:59 PM
Drewzown's Avatar
So everything is installed the driver side cv axle was different. The transmission is resting on the sub frame??? Never seen that before bad mount?
I am getting speed sensor codes I will try using the Altima transmission sensors to fix the the issue, but anyone ever heard of transmission on subframe?
Old Mar 30, 2016 | 02:25 PM
Mattx's Avatar
So everything is installed the driver side cv axle was different. The transmission is resting on the sub frame??? Never seen that before bad mount? I am getting speed sensor codes I will try using the Altima transmission sensors to fix the the issue, but anyone ever heard of transmission on subframe?
I'm not sure what you mean when you say transmission on subframe. Maybe you could take some pictures.
Old Mar 30, 2016 | 05:35 PM
Drewzown's Avatar
I mixed up the connectors on the transmission I wish that was more clear this picture is amazing
I find this weird because the pan is even more shallow than an Altima pan
Infiniti04
Jan 23, 2016 04:48 AM
jlee
Jan 19, 2016 01:36 PM
jerrod99_se-l
Jan 13, 2016 05:28 AM
P0tter7
Jan 7, 2016 04:32 PM
