Brake problems - Caliper or MC or ?
Car is a 2002 SE with auto trans. Long story short on the car. It sat for some time with many issues. Engine and transmission have been replaced. Working on the brakes now.
Replaced all calipers, rotors and brake lines as the old ones were of questionable use. Brake fluid was pretty old. So, lines were completely drained when old calipers were removed. Brakes were then bled, but still mushy pedal. Bled the MC using the FSM method, but no change. Bought a kit to bleed MC (plastic adapters with clear tubing). I bled the MC with the clear tubing placed in the MC reservoir and pumped pedal until no air was seen. This did not solve the mushy pedal. After each attempt of bleeding the MC, all calipers were bled as per FSM steps.
Thinking I might have a bad MC or something else wrong. I pulled the MC off a parts car and bench bled that. I then noticed that the front calipers were installed on the wrong side as the air bleeder was on the bottom. So, I swapped those.
Now this time after making sure the replacement MC was bled, I went about bleeding the calipers. Started at RR, then FL, then RL. When I got to the FR, it was very weird. I'm bleeding using a mityvac hand vacuum pump. On the FR, I connected it and it would hold vacuum just fine. When I opened the bleeder I would get a few seconds of fluid coming out and then it would just constantly bubble. Nothing like there was a small air leak at the bleeder or so as those are typically very small bubbles. This was more like a very large leak or the line was almost totally empty.
Here is a video I took of the situation:
https://picasaweb.google.com/lh/phot...eat=directlink
Could find a way to embed the video - sorry.
Anyways, I'm hoping someone can help me figure out what might be causing this. I've bled brakes many times before and never had something like this happen.
The small bubbles you get when holding vacuum are air being sucked through the threads or where the tube fits on the bleeder valve. You don't get this with pressure bleeding.
If you want to eliminate it you can use a small amount of thread tape on the bleeder valve and zip tie the hose to the bleeder valve for a tighter fit.
I'm wondering, what would dirt or something clogging the line look like? Anyone know which brake line coming out of the actuator is the one for the FR caliper? The FMS shows the one closest to the front of the vehicle being the one for FR caliper. Can I take that as fact?
A clogged line wouldn't cause your bubbles. If it bled without issues and it was sealed while it sat there probably aren't any clogs.
If you are sucking air from anywhere it's most likely the connections on the new brake line. See if you can tighten them any further without stripping them.
I would also try pressure/pump bleeding the brakes with a partner. You're less likely to suck in air and if there is a leak it will show as a fluid leak.
I bought a vacuum bleeder and don't use it. It's pretty pointless. I do use the reservoir and hose, though. You can pump the pedal yourself and you're done in no time.
Last night I went ahead pressure bled that caliper. Didn't see any issues during the bleeding and everything is working great now.
Not sure why that caliper was so picky being bled, but glad it is working now.
Thanks for all the suggestions.
