Torque steer
Old Apr 24, 2016 | 09:17 PM
mrjamaica98mx's Avatar
Torque steer
Having torque steer when i hit on gas hard at light car feels like i am going to hit car to right of me. How do i resolve
Old Apr 25, 2016 | 06:33 AM
losifanatic's Avatar
What kind of shape are your tires in? Bad tires can amplify the effects of torque steer
Old Apr 25, 2016 | 09:16 AM
MadMax SE's Avatar
If you get the chance, inspect your motor mounts and tranny mount. under accell they can compress the rubber on the inside if there bad enough. that can cause torque steer. Also inspect your control arm bushings and all the bushings around them. You wouldnt believe how much an old worn bushing will shift around. Replacing those bushings with polyeurothane bushigs would greatly reduce torque steer, and if you enjoy launching from a stop or burnouts its also a plus because the suspension wont bind as bad as factory rubbers. i would drop the clutch in my older avenger and insteading of burning out it shudderd it self to death, i could feel the loose *** suspension.
Old Apr 25, 2016 | 03:45 PM
Yup the motor mount passenger side is bulged out.
Old Apr 25, 2016 | 04:17 PM
DennisMik's Avatar
That's the way they are made, but it is possible that the bulge is more than normal. You have to compare it to a new mount.
Another thing to check would be the lca bushings. Especially the right side because so many of these cars have leaking power steering hoses and the atf rots the bushings.
Old Apr 25, 2016 | 04:53 PM
I have to do that to my daughters 03.
Old Apr 25, 2016 | 05:57 PM
Adamk8824's Avatar
anyone else thinking axles? I had to replace both of mine.
Old Apr 25, 2016 | 09:57 PM
Ty will do
Old Apr 25, 2016 | 10:15 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Fix? HLSD :P
Old Apr 26, 2016 | 06:41 AM
rvamax's Avatar
I had a similar issue, it went away after I replaced the tires and driver side tie rod ends.
Old Apr 26, 2016 | 05:17 PM
VQ35maxima=Beast's Avatar
Check the lower control arm bushings, had the same issue on my 00, and 02, control arms with ball joints and bushings fixed it.
Old Apr 27, 2016 | 11:32 AM
Replacing today hoping for improvement
Old Apr 28, 2016 | 08:11 AM
Prophecy99's Avatar
keep us posted
Old Apr 28, 2016 | 08:56 AM
Derrick2k2SE's Avatar
Fix? HLSD :P
Ultimately this is the best fix. Everything else is just a Bandaid on a bad design. Find an 04+ tranny with HLSD.
I can hammer in the rain with both tires struggling for traction and the car goes dead straight. Even when the tires are worn out. It never jerks to the side. I can even punch it in a turn and have it stick or create a controlled slide at will. No plowing.
Before the swap it would jerk to the right if I punched it in the rain or hit a puddle. Forget about punching it in a turn. It would just plow straight.
Overall acceleration and handling are so much better even in the dry. It really amazes me that they didn't put HLSD in all of the MT cars.
Old Apr 28, 2016 | 05:36 PM
Old Apr 28, 2016 | 11:08 PM
Bad *** Newb
Absolutely. I can barely break traction in 1st with my 5.7 swap on half *** "all season" tires.
urdunfer
Apr 19, 2016 09:15 AM
CS_AR
Apr 17, 2016 11:27 AM
SSC
Apr 13, 2016 11:16 AM
pewterss
Mar 29, 2016 05:19 PM
