car revs high under light acceleration then returns to normal
Old May 4, 2016 | 07:46 AM
rvamax's Avatar
Car is an 01 gxe auto. Less than 50k miles. No check engine light. The car will rev to between 2500 and 4k rpm under light acceleration from a dead stop and will return to normal operation at about 30mph. Other issues, somtimes the turn signal will stay on at double speed after a lane change. It is not a burnt out bulb. Also sometimes the radio will switch to fm. to am on its own.
Old May 4, 2016 | 08:11 AM
NmexMAX's Avatar
dot dot dot ...
I'm officially jelly.
Need a more detailed explanation, sounds normal for an auto to me.
I'd try changing the bulb anyway, cheap and easy. Is it always the same direction that does that? Maybe a dying relay/loose bulb.
You car may in fact be possessed.
Old May 4, 2016 | 08:42 AM
rvamax's Avatar
The increase in engine rpm is abrupt and does not match the rpm appropriate for the pedal pressure being applied.
Old May 4, 2016 | 10:19 AM
NmexMAX's Avatar
dot dot dot ...
Slipping tranny seems like.
Old May 4, 2016 | 11:19 AM
rvamax's Avatar
I hope not. Its only happened twice. Today and about a two months ago. It starts acting up out of nowhere and then goes away. Is it electrical? I thought installing a grounding kit would fix these bugs but it hasn't had any effect. I didn't think mechanical issues had these kinds of characteristics. Would a transmission flush be a good idea or should I just take it to a shop and say fix it.
Old May 4, 2016 | 11:43 AM
NmexMAX's Avatar
dot dot dot ...
If it's in a drive gear and that happens and the car doesn't lurch forward, then yes, it's mechanical and possibly slipping tranny/clutch.
Old May 5, 2016 | 04:56 AM
BigLou55's Avatar
Have you checked your tranny oil level (warmed up and ran through all the gears) and condition? sounds simple but that level needs to be within range.
Would not recommend a flush. Maybe a drain and refill but I would not start spending money on a fix until you know what the issue is.
If you go to a shop and say "fix it" you would be surprised as to what they find.
Old May 5, 2016 | 03:17 PM
rvamax's Avatar
Levels are good, doesn't smell burnt and looks clean, hard to tell what color it is almost looks clear with a pinkish tone.
Old May 5, 2016 | 03:54 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Did you buy it recently?
Perhaps the fluid was changed with something dastardly. Seems like awful low mileage to slip for no reason.
Old May 6, 2016 | 05:03 AM
MadMax SE's Avatar
I would take a look at the iacv, when mine broke I could just tap the gas and it would rev up to 3k at times by it self. Under light throttle the auto tranny is expecting to shift at 2000 rpm at 21% throttle(example). With the broken iacv your throttle is still at 21% but now your rpms go higher than when you would normaly hold the pedal in the same position, so when the computer thinks it's time to shift, it tries to shift but jerks because of the unexpected rpm rise.
Old May 6, 2016 | 06:54 AM
rvamax's Avatar
Thanks. It has only happened twice could it just be dirty?
Old May 10, 2016 | 07:09 AM
rvamax's Avatar
Added stop slip and the transmission issue went away however the clicking is back, it only happens when I hit a bump while signaling left in the rain, possible engine mount grounding issue?
2014Maxima
Sep 9, 2016 10:19 AM
tarun900
Mar 13, 2016 11:09 AM
zachpark17
Mar 5, 2016 08:50 AM
chevyman1980
Mar 5, 2016 05:17 AM
lux97Max
Mar 1, 2016 10:47 PM
