2002 -- SES, SLIP and TC OFF -- wtf
Old May 8, 2016 | 04:53 PM
96SEmaxB's Avatar
So started with torn boot on the coupler going from TB to maf, cleaned maf fixed tear in coupler, drove great for a week, went and got gas today omw back I goosed it at a stop sign, went to 2500rpm and wam, no power and was shuddering like I was hitting a limiter, lights immediately came on cel, tc off and slip, so I limped home and immediately ran code scan manually, got p1130, and p1614 - only worried about the p1130, but do u think a faulty MAF would cause this issue, I've been reading the bulitens and forums all day and idk, I'm going to pick up a junkyard MAF tomorrow and start with that, but I suppose I run a chance of that being bad also, what's the link on here that shows symptoms of dead and damage MAFs?
5.5s are so sensitive Compared to the 4th gens...sheesh
Old May 8, 2016 | 07:15 PM
96SEmaxB's Avatar
OK now I'm reading that slip/tc off and ses could be bad alternator also... Guess I'll have to check that also. And grounds, I just find it strange that it happened all of the sudden...I'm still reading threads...my wife keeps looking at me like *your on those forums....still?*
Old May 8, 2016 | 07:21 PM
cornholio's Avatar
haha, keep sifting though the threads and broken links and you'll eventually find what you're looking for
i was thinking some combination of those lights pointed to the wheel speed sensors ? not for sure though
Old May 8, 2016 | 07:35 PM
Child_uv_KoRn's Avatar
Bad *** Newb
The codes don't make sense. There is no swirl control valve (couldn't find anything related to a different meaning for 3.5s). And obviously the car is running, so the NATS code is retarded.
I would swap maf and reset ECU. See what codes/lights (if any) come back.
Old May 8, 2016 | 08:04 PM
96SEmaxB's Avatar
I'm going to try that tomorrow, the MAF housing looks in good shape, so just gonna look for the conductor part in the middle and try that as well as an alt test, will update tomorrow.
Old May 10, 2016 | 05:36 AM
96SEmaxB's Avatar
Update
junkyards didn't have anything, so I ordered a MAF sensor off eBay, went with the ****ty 6N200 for like 30$, Atleast if that fixes the problem temporarily, I'll then know what I need to replace before I 100$ myself to death.
Working 70hrs/wk so don't have time to do ****, but I was reading that incorrect amps coming from alternator could mess with the MAF, is that true?
Old May 10, 2016 | 12:00 PM
Bad *** Newb
Originally Posted by 96SEmaxB
Update
If the voltage was too high, then it would set off the lights just as if it were too low. If you didn't have enough amperage, then the battery would drain and you'd have a non-running car.
Old May 10, 2016 | 12:27 PM
george__'s Avatar
Alternator
Old May 10, 2016 | 12:49 PM
96SEmaxB's Avatar
Ok I'll check that, I was reading there's a way u can test it by unhooking the battery while it's running, I have a volt meter too, just have to check and see what the correct volts should be coming from the alternator.
Again, symptoms are:
2500 Max rpm
Slip / track off
Ses light
Fluctuating rpms 250-700 while in park
I checked coils they all test good, plugs are good, recently all I did was unplug sub woofer amp (in process of fixing that relay) and right after that it had these problems.
Old May 10, 2016 | 06:32 PM
96SEmaxB's Avatar
Update on codes,
Hooked everything back up to the way it was before I had issues, had the bat unhooked for two days, these are the codes
P0102 - MAF
P1456 - EVAP
P1131 - no clue why I'm getting this code.
So I'm hoping just swapping MAF will do the trick and cure my issues. Few more days till that gets here.
Old May 12, 2016 | 06:35 PM
96SEmaxB's Avatar
Update
Just put in eBay 19$ MAF, POOF it's fixed. Amazing how sensitive those things are....thanks for all the help guys
Old May 12, 2016 | 09:11 PM
maxinout93's Avatar
Update
great to hear that!! Might be my issue also.
Old May 13, 2016 | 07:46 AM
96SEmaxB's Avatar
It was a pain to diagnose because I had multiple codes but once I figured out the symptoms (tsb) I just went with cheapest fix first, now I know it was the MAF and it only cost me 19$ shipped for an eBay MAF, now I am going to go the 2001 MAF with the IAT swap.
mrjamaica98mx
Mar 30, 2016 08:14 AM
Young Guy
Mar 22, 2016 05:52 AM
Max I am
Mar 9, 2016 03:12 AM
enterconnect
29
Mar 2, 2016 11:26 AM
adsinclair
Feb 16, 2016 05:14 PM
