Huge loss of power
Old May 25, 2016 | 07:51 PM
sebastian2041's Avatar
Huge loss of power
So lately i noticed my car had a huge loss of power having a really big exhaust leak i thought it was that but then the leak was fixed and the problem is still there. I just ordered obx r headers but i want to fix this power problem before installing them any ideas are helpful (the car has new plugs)
Old May 25, 2016 | 07:53 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Perhaps headers will solve the problem
Old May 25, 2016 | 07:54 PM
Cotozic's Avatar
Where do you feel the loss of power most? Does it feel less responsive? Does it feel like it's running rough or uneven?
^^ and yeah, no more pre-cats.
Old May 25, 2016 | 08:10 PM
Derrick2k2SE's Avatar
I'm also curious where the power loss is and if there are other issues.
Is it running like crap or does it just feel like a four cylinder Camry?
Old May 25, 2016 | 08:33 PM
Well the obx r headers are on the way they have been ordered i just want to know my problem before i put them in.. The car feels like a camry maybe worse! Very slugish i can push the pedal to the floor and i barey feel a jump! Even when down shifting! I do need an oil change but doing it saturday, i feel like its maf related since my mechanic friend told me he was going to clean it and the way he cleaned does really match how the "how to" stickie thread shows
Also idle seems fine the car isnt rough or uneven just feels like im driving a stock miata!
Old May 26, 2016 | 05:27 AM
This may sound crazy but check to make sure the brake lights aren't staying on. I had a similar issue when the stopper on the pedal broke and left the brake lights on. The computer cuts the throttle when the brakes are applied and reads it form the brake light switch. The car drove perfectly but felt exactly like a weak 4 cyl.
I doubt this is your problem since it's been going on for a while and you haven't noticed the lights. It's easy enough to rule out though. It had me stumped till I closed the garage door but I would have noticed at night.
Old May 26, 2016 | 05:42 AM
tech2000's Avatar
When the the last time you did a tune up?
Old May 26, 2016 | 06:41 AM
So i did oil february( which i have been told the one i got is **** for our cars) i have new oil waiting to go in but i want to put the car on the lift so i can have a full check up on it and thats being done on Saturday, spark plug and boots were put in 1 month ago, clutch and fly wheel done February. I did add the NWP BOP recently but im not sure its the problem. I did extent my intake so the filter sits behind headlight so i might of just blew my MAF? Im at the point where i think its a vacuum leak, MAF and oil. I have a pretty ghetto rig for my intake while i wait for my CGR intake
thermostat was also done last month
Actually my brake lights were just recently changed
Old May 29, 2016 | 09:03 AM
MadMax SE's Avatar
Did you reset the ecu after you did the repair? It's possible that it's running ignition and fuel timing that was used for the broken exaust being that there's no way for the ecu to even know if you fixed anything or not.
Old May 29, 2016 | 09:06 AM
MadMax SE's Avatar
What kind of plugs went in? I know these cars are pickey about plugs, my max was misfiring on all cylinders because the previous owner used Bosch plugs and they were still new.
Old May 29, 2016 | 09:41 AM
I did not reset the ecu will try that, ngk LFR5AIX-11. The leak was huge ( if yoi can call it a leak) y pipe was essentially broken i dont know why but i welded it back up till the obx r headers arrive.
Old May 29, 2016 | 12:29 PM
Bad *** Newb
That was made to go on the precats? Man, went so far, but fell so short
Old May 29, 2016 | 01:55 PM
Reset ecu with some pedal dancing, now for the ecu to really djust. Feels better but i know the rear cat is gone since i was able to take stuff out of it when i tookmthe y pipe out to weld it. Obx r come in on Wednesday, new multi layered gaskets come in on thursday project begins friday afternoon hopefuly done by saturday. This car is mint but has lots of little issues i have to work on.
Yes that was the y pipe to the pre cats...
Old May 31, 2016 | 11:24 AM
maxinout93's Avatar
most likey once you install the headers you will get the power back.
Old Jun 3, 2016 | 07:39 PM
Bad *** Newb
Check his pics in the "what did you do to your 5th gen today"
OMG, that thing was 99% plugged!
Old Jun 3, 2016 | 08:08 PM
TheEddyGrimes
Feb 10, 2018 06:45 PM
Nathaniel Freeman Jr
Mar 15, 2016 11:46 AM
shoneyzz
Mar 11, 2016 09:44 PM
shoneyzz
Mar 11, 2016 12:45 PM
simpy49
Mar 9, 2016 06:57 PM
