Code p1448 evap vent control valve?
Old Jul 11, 2016 | 03:15 PM
Maxboy23's Avatar
This is a new one for me never heard of it the scanner said evap canister vent control valve open does anyone know what it could or the part number for this item?
Old Jul 11, 2016 | 05:11 PM
Max139617's Avatar
Search it's been covered multiple times before. It's located behind the rear driver wheel
Old Jul 11, 2016 | 05:17 PM
Maxboy23's Avatar
Oh ok gotcha i just seen some videos its just that switch right not the canister?
Old Jul 11, 2016 | 05:55 PM
Max139617's Avatar
OnlyIf you think the vent bolts won't break which they usually do due to rust you should go ahead and replace the box
Old Jul 11, 2016 | 07:43 PM
Itz Shak's Avatar
I guess if I'm going to hijack, this is as good a time as any
So my car ran out of gas today @ half tank, forcing me to use that old faithful gas can in the trunk.
I have the p0455/p1448 code but I was told that these wouldn't cause our gas needles to read wrong. (Which makes sense)
Could it be the Fuel pump or sending unit? I saw in a thread that our cars fuel pumps and sending units don't usually go bad. When it did run out of gas, I heard a popping sound from under the hood. Almost like a leak.
Any help is appreciated, as I'm Kinda stumped..
Old Jul 11, 2016 | 10:08 PM
DennisMik's Avatar
The fuel pump can't cause the fuel gauge to read incorrectly. It is either the gauge itself or the sending unit.
the instrument cluster has a diagnostic built into it that will point all the instrument gauges to a certain spot. This will tell you if the gauge is good or not.
See page 122 in the 2002 EL section for diagnostic instructions. (Link below)
Step 7 of the procedure that points the needles is slow in moving the needles. It might take as long as a half minute.
http://boredmder.com/FSMs/Nissan/Maxima/2002/EL.pdf
Old Jul 12, 2016 | 04:37 AM
Prophecy99's Avatar
caulk the crap around the entire canister where u think leaks could occcur, done,
way better than replacing w a part, it was easy and got rid of my code P0455
Old Jul 12, 2016 | 10:19 AM
Itz Shak's Avatar
Thanks fellas, will do.
Old Jul 12, 2016 | 09:21 PM
Itz Shak's Avatar
I just adjusted my gas needle as 2kmaxim suggested in this thread https://maxima.org/forums/5th-genera...l-problem.html (post #33) My needle was a little lower than the fsm before my adjustment so we'll see if that fixes the problem, otherwise fuel sender unit it is.
I'll post results here
Old Jul 13, 2016 | 07:47 AM
Itz Shak's Avatar
Okay, so I haven't seen the p0455 come back yet. (but it's only been one day, so i'll wait)
The gas issue.. after adjusting the needle, the gauge seemed to read properly for a moment. Then it rose right back up to over half tank, when I know it should be near or a little lower than 1/4 tank.
Here's a picture of the diagnostic after I adjusted the needle
Here's a picture of where the needle is now.. when it should be @ 1/4
Some car gauge pro screenshots, hopefully this helps?
(voltage ranged from 0.96 to 1.16)
Fuel Temperature
Base Fuel Level Schedule here
Old Jul 13, 2016 | 08:27 AM
DennisMik's Avatar
I have never measured the voltage to the gauge, so I have no idea what the voltage should be. Do you know anyone in your area with a Maxima you could hook your gauge pro to and compare with.
But if the diagnostic positions the needle correctly, then I have to assume that the sending unit in the tank is bad.
Old Jul 13, 2016 | 09:16 AM
Itz Shak's Avatar
Unfortunately I'm assuming the same
I found this chart on page 3 as far as the voltage goes..
http://www.racetronix.com/Manuals/C5...%20Voltage.pdf
biftikhar1989
Jan 26, 2017 04:49 PM
SquidBeak
Jul 15, 2016 07:21 AM
KOWGIRL47
Jul 13, 2016 02:02 PM
Montego Murph
Jul 13, 2016 08:17 AM
phaedriz
Jul 8, 2016 03:03 AM
