Slight coolant level drop okay?
Old Aug 26, 2016 | 08:01 PM
mclasser's Avatar
When I changed the rad last year, I filled up the overflow tank to the hot MAX line. Now the hot level's about 1/4 below MAX. Is it normal for air to bleed out the system over time and slightly drop the level like this? Don't see any leaks anywhere.
Old Aug 26, 2016 | 08:29 PM
Donkeypunch's Avatar
It might be your water pump.
Old Aug 26, 2016 | 09:28 PM
DennisMik's Avatar
It might be air bleeding out and it might be another leak. Top up the tank and keep an eye on it.
Old Aug 26, 2016 | 09:57 PM
air is going out. coolant is getting in.
No leaks but coolant still goes down it's the water pump.
Major wear acceleration. make sure that's it, and change it asap.
Old Aug 27, 2016 | 03:44 AM
maxinout93's Avatar
How can you tell for sure its the water pump tho? Is it an expensive repair?
Itz Shak
1/4 and 1/8 Mile Racing
24
May 9, 2017 07:56 AM
jmlee44
Apr 13, 2016 10:11 AM
thekevinwright
Mar 15, 2016 08:51 PM
LosAngelesMaxima
Mar 15, 2016 02:20 PM
mrb23
Sep 1, 2000 10:11 PM
